FS: Ground Control DOUBLE ADJUSTABLE Coilovers - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 07-09-2006, 02:59 PM   #1
TheFallen
Flying Low
My Ride: 03 SMG II
Send a message via AIM to TheFallen
For Sale: GroundControl Double Adjustable Track/Race kit w/ top adjustable rear shock option paired with 500 lb / 550 lb ERS Eibach Springs
(6inch front, 6.5 inch rear)
It is pretty rare for GC kits go for sale, and even more rare for one that is of this caliber. This kit go for no less than 2000-2100 dollars
Miles: 7800 miles on the kit, but almost all major components(rear shocks, 4 springs and front shocks) were upgraded only within the past 4000 miles with new GC parts of course. Only original parts are the camber/caster plate, RSM and 4 bump stops.
Price: $1500+shipping
Reason for selling: Considering MOTON Clubsport
** just a heads up, lowball offers will not be responded to. Dibs will be given to first local buyer.
Kit Description:
2 SHORT Koni double adjustable struts in Ground Control shortened strut housings
Complete Shortened Front Strut Housing Machined from seamless DOM 1026 steel alloy tubing. Heavy-duty sway bar bracket welded on. Our design is much stronger and more rigid than any of the aftermarket housings that are actually modified stock housings, with skip-welded gussets and and all original brake line and abs tabs retained.
Koni double adjustable strut Externally adjustable rebound on top, externally adjustable compression underneath the strut.
Ground Control Threaded Sleeves This system is designed to eliminate stress risers caused by machining notches into the strut housing. Unlike other companies that claim superiority by cutting threads into a critical component of the suspension, Ground Control uses engineering common sense to maximize the strength of the suspension.
Ground Control Adjustable Spring Perch A unique design, which uses an Allen head bolt to clamp the single threaded perch into the correct position. No secondary pieces are needed to "jam" the threaded perch into position.
2 SHORT Koni single adjustable rear shocks
Koni Single Adjustable Rear Shocks Preadjusted to match rear spring rates using our shock dyno. The rear shocks are custom valved for Ground Control, made by Koni in Holland and are the "top-adjust" version, which adjusts from inside the trunk with no tools needed.
1 Pair front Camber Plates
Ground Control Racing Camber / Caster Plates More camber adjustment than stock, caster adjustment, aircraft bearings, engraved with calibrated degrees, with stainless steel reinforcement. Every component is anodized or plated, including fasteners. Adds extra travel to avoid excessive bottoming out, this is a very well engineered product. The stainless steel reinforcement prevents electrolysis between the steel fender and the aluminum camber plate.
Camber and caster are separately adjustable by sliding the mounts, without removing any components from the car. The priority of this design is to allow fast, repeatable alignment changes at the track.
The Ground Control camber plates feature two sets of bearings, a proprietary bearing, made to our specs by Aurora in the USA, which allows for articulation of the shock shaft. This spherical bearing is very under stressed, as the Ground Control design does NOT support the weight of the car on the spherical bearing. Instead, the weight of the car is supported by a completely separate articulating needle bearing, which is also manufactured for Ground Control in the USA.
4 Eibach ERS springs, any racing spring rate
Eibach Spring Any spring rate is available. Eibach springs are made on German machines both in the USA and in Germany, however all Eibach springs have a lifetime guarantee against sagging, rate change, or any manufacturing or material failure. Lifetime guarantee. Compare.
** for this kit: 500lbs ( 6 inch ) fronts and 550lbs (6.5 inch) rears
4 Ground Control bump stops (made in Germany)
Ground Control Bump Stop We do not just ask you to reuse your stock bump. The stock bump stop is designed for stock suspension we provide a bump stop designed to work with our suspension. These are soft foam, same quality as OE BMW parts, but made to our specs in Germany. Our race bump stops are even different than our street bump stops.
2 rear ride height adjusters
Ground Control Rear Ride Height Adjustment Kit Billet aluminum threaded adjusters bolt on top of the rear control arm. The e36 M3 has a larger diameter rear axle than the standard e36, so it is necessary for clearance to not have any portion of the adjuster below the control arm.
Kevin
TheFallen is offline   Reply With Quote
Old 07-11-2006, 02:06 AM   #2
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
So what's the fitment on this kit? e36 or e46???
/// MODS
/// Auto => 6-Spd Manual Conversion | Apex EC-7 | Koni/Ground Control Coilovers | Vorshlag Camber Plates | BMW Performance LCA | Mishimoto Intake Boots | GruppeM rep CAI | Shark Injector | 5000k Xenarc CBI 66240 HID | BMW European MTechII | BMW Performance Shifter | ACS Mirrors and Rear Spoiler ///
Old 07-11-2006, 09:18 AM   #3
TheFallen
Flying Low
My Ride: 03 SMG II
this kit is coming off of my E46 M3, sorry for not specifying
Kevin
Old 07-11-2006, 09:34 PM   #4
W4rmachine
My Ride: oNe sLo 3twenty3
Send a message via AIM to W4rmachine
Damn tahts alot of info man.
[BMW 323ci] Mods: AA Supercharged C30 Kit | AA Gen 3 exhaust | OEM M3 front | Vorsteiner Hood | Custom paint Volk TE37 | GTR sideskirts | Hamann rear addon | HKS Hipermaxx Coilover | Voltex GT Type 1 Wing | OEM M3 side mirror | Autentic ACS Lip |
W4rmachine is offline   Reply With Quote
Old 08-17-2006, 10:45 PM   #5
mfnatic
My Ride: m3
Send a message via AIM to mfnatic
dibs
mfnatic is offline   Reply With Quote
Old 08-18-2006, 03:22 AM   #6
TheFallen
Flying Low
My Ride: 03 SMG II
sold for 1400
Kevin
