Old 07-11-2006, 04:14 PM   #1
SK328CI
SK328CI's Avatar
My Ride: 2006 Jeep SRT8
whats so special about bmw coolant
I am going to get a coolant change and wanted to know whats so special about the BMW coolant.
I hear that you have to get it from BMW and mix it 50/50 with distilled water then put it in.
As anyone put regular antifreeze in there? Or is the genuine bmw coolant necessary for our cars?
SK328CI is offline   Reply With Quote
Old 07-11-2006, 04:17 PM   #2
S2Krazy
A Flammable Plumber
S2Krazy's Avatar
My Ride: ****ED UP CL
Send a message via AIM to S2Krazy Send a message via MSN to S2Krazy
nothing
S2Krazy is offline   Reply With Quote
Old 07-11-2006, 04:19 PM   #3
cgrizzly888
My Ride: 00 328i
Send a message via AIM to cgrizzly888
Only use bmw coolant, otherwise, you risk ruining your cooling system.
cgrizzly888 is offline   Reply With Quote
Old 07-11-2006, 04:23 PM   #4
joserse46
My Ride: 2001 325I
well from what I was told the BMW stuff has no phosphates or nitrates which will mess up the seals and gaskets so just get coolant without those ingredients and you should be OK
joserse46 is offline   Reply With Quote
Old 07-11-2006, 05:46 PM   #5
e330zhp46
e330zhp46's Avatar
My Ride: (SEE SIGNATURE)
you also have to make sure that your new coolant wont start to create caviatation around the cylinders....the block is aluminum, and any air bullbles that form can be detremental to the walls of the cylinders.....i would look at the ingredients of both before switching it out.....
_______________________________________________Has Three Pedals__________________________
** sig size and layout changed by tim330i to reduce side scroll ** sorry my monitor is 1680x1050 so there is no side scroll for me
e330zhp46 is offline   Reply With Quote
Old 07-11-2006, 05:51 PM   #6
Choson1
Owner
My Ride: Keepin' it Real
you can use other brand coolants as long as they meet the specifications outlined in the manual.
Choson1 is offline   Reply With Quote
Old 07-11-2006, 05:53 PM   #7
UnBreakable
My Ride: OB E46 328i
Some Antizees have no corrosion inhibitors, meaning they have no protection agaisnt corrosion. Also some cheap brandnames have corrosive agents and can corrode your aluminum block. Some will leave residues on the coolant passages leading to overheating or hotspots.
Image Hosted by ImageShack.us
-l-
'---0-(_)-0---'
UnBreakable is offline   Reply With Quote
Old 07-11-2006, 07:01 PM   #8
shortyb
My Ride: Has blue lights
BMW coolant is silicate free, phosphate free, amine free, and borate free. This keeps things nice and happy amongst all the dissimilar metals, plastics, seals and rubber in the cooling system. It is sourced from Pentosin, a very reputable European fluids manufacturer and supplier along with development from BASF. It is relatively expensive for this reason.
Granted it is twice to three times what OTC coolant is at the local parts superstore but coolant only needs to be changed every 2~4 years. Amortize the cost difference over that time period and it comes out to .60 a month for the two year interval. Can't even get a Happy Meal for that. I say feed your Bimmer well and use the OEM coolant.
shortyb is offline   Reply With Quote
Old 07-11-2006, 08:07 PM   #9
curious_george
My Ride: '02 325i ZSP
Hey - I thought my coolant was low and tried to top it off with some coolant I picked up at the gas station (50/50 premix, generic). Long story short, it did not really need to be filled up like I thought and I only put maybe a cup in (at most). Should I be concerned at all about getting it flushed and refilled? It was listed as low silicate formula. I have never thought much about coolant other than making sure it is mixed with distilled water.
curious_george is offline   Reply With Quote
Old 07-11-2006, 09:04 PM   #10
BattleWagon
My Ride: Colnago CT-1
I heard its Zerex G05 formulation with blue coloring for BMW
BattleWagon is offline   Reply With Quote
Old 07-12-2006, 10:58 AM   #11
hummer
My Ride: 2001 330CI
What's so special about BMW coolant?
It makes BMW a lot of profit!!!!!
They are all ethylene glycol and if used with distilled water, there is no problem with Prestone or similar long life anti-freeze. Prestone's bottle is trying to dispell the myth that everybody's stuff is different because the color is different. It's called MARKETING! Prestone can be "used with any color anti-freeze" It's mixed in mine with BMW coolant since going off maintenance warrantee and soon to be totally flushed.
Old 07-12-2006, 11:18 AM   #12
TwoE46s
My Ride: Dinan 330ci & 325it
I really don't get this - BMW, as well as the guys that write the tech columns for Roundel and Bimmer who have a lot more experience servicing BMWs than anyone on this forum, say only use BMW coolant. Frick guys, if you pay the dealer to flush your cooling system every 2 years it's $100, and maybe you buy a gallon to keep in the garage for top offs for $30. Other than oil, its' what keeps your engine alive.
Why all the hand wringing over this given the cost of your car - I mean there are people here that spend hundreds of dollars on bling and stereos, yet sweat paying $100 for the right coolant. A tricked out car with a blown headgasket and $3000 bill to get fixed or failed radiator sitting on the freeway doesn't sound too cool to me.......................
TwoE46s
01-Dinan3/330ci (sold); 03-325it; 07-E92/328; 06-Cayman S
Wagon:
17X8 BBS RXs & 225/45 Toyo Proxes 4s
Coupe:(sold)
Dinan "S" plus Throttle Body & Stg 3 Software
Dinan Stage 2 Suspension
UUC Shifter
UUC Underdrive Pulleys
Goodridge Braided Brake Lines
Michelin Pilot Sport PS2s on factory M Double Spoke 68s
Track Stuff - 17X8 OZ SuperLeggeras & 235/40 Toyo RA1s; Shroth Harnesses
TwoE46s is offline   Reply With Quote
Old 07-12-2006, 12:58 PM   #13
halcyon
My Ride: 99 328
Why is BMW coolant special you ask?
Because it's a pretty blue color. Blue makes me happy. Ah look at the blue.
halcyon is offline   Reply With Quote
Old 07-12-2006, 02:17 PM   #14
mfanatic325
My Ride: '01 911 Turbo
HOray for blue!
mfanatic325 is offline   Reply With Quote
Old 07-12-2006, 03:18 PM   #15
curious_george
I was hoping someone would see my question and answer it. I would gladly buy BMW coolant, but it is not like the stuff is available at the local Exxon (which, incidently, is where I picked up some no-name stuff that I used). Anyway, I ended up putting less than a cup in the car. Should that even be a consideration as far as flushing out?
In addition, I would have to say that the fact that the BMW coolant is labeled "BMW" is not important - I suppose it is the characteristics. The same stuff is surely available from other vendors, as they are the ones who supply BMW no doubt. BMW does not have a coolant production factory. This reminds me of the BMW windshield threads.
Old 07-12-2006, 04:07 PM   #16
mfanatic325
george -may I call you george?- I'm pretty much in the same boat as you are. I put in Prestone (about 3 cups of anti-freeze + 1 cup tap water) in my coolant tank...even though it's for all makes and models, I am still going to have it flushed out and topped off next Wednesday at my dealer just to be safe. I suggest you do the same. This way, they can't ever blame engine problems on bad coolant g'luck!
Old 07-12-2006, 04:23 PM   #17
halcyon
My Ride: 99 328
Righto.
A little Prestone won't hurt your car. They all have to conform to the same minimum standards. I would use the BMW coolant and some nice distilled water when flushing the system, but for just a little top off, the green stuff won't hurt.
Speaking of which, I still have a gallon sitting in my living room. I should probably flush the coolant soon.
Old 07-12-2006, 05:18 PM   #18
TwoE46s
The coolant (or windshields) are certainly not made by BMW. However, I am sure in the auto industry as with many others, OEM agreements with the actual manufacturers of a product, can include exclusivity rights on the design / formulation, so that you can not buy exactly the same thing off the shelf.
By the way, if you were only a cup low, I would have just added some water, not another coolant...............
TwoE46s
Wagon:
Coupe:(sold)
UUC Shifter
Old 07-12-2006, 05:29 PM   #19
xchromex
My Ride: 08e90m3
i dont use anything...
my car is already... "cool" :]
never over heats.. HOORAHH~
xchromex is offline   Reply With Quote
Old 07-12-2006, 05:40 PM   #20
SK328CI
SK328CI's Avatar
im not being picky about not spending money, i will go to pick it up from the dealership, i am just curious to ask why it has to be BMW coolant.
i mean almost all other cars let you use brands you can find from any local auto shop.
