Old 07-27-2006, 12:49 PM   #1
JAe46
My Ride: 2003 325ci
oem non xenon to oem xenon
is it possible to put m3 xenon headlights to my 325ci non xenon? what do i need to make it happen? will the computer recognize it?let me know peeps
JAe46 is offline   Reply With Quote
Old 07-27-2006, 01:03 PM   #2
yogo_jonzo
My Ride: 2006 325i Alpine
Yes it is possible. Check the DIY forum and you will find all kinds of info. If your car is pre-facelift the M3 lights will go right in. You may need to change the lense covers though, and find a way to mount the corner lights.
Or I also wrote a DIY about taking the headlights apart and swapping them into your existing halogens.
Also the computer will need to be re-flashed to recognize them, or just remove a fuse (32 I think) and it gets rid of the error on the dash.
yogo_jonzo is offline   Reply With Quote
Old 07-27-2006, 05:57 PM   #3
JAe46
My Ride: 2003 325ci
thanks for ur tips? has anyone else done this the more info the better...i installed one and it didnt light up does that mean i got to reflash the computer?
Old 07-27-2006, 06:17 PM   #4
kwlaznkid
kwlaznkid's Avatar
My Ride: 335i/M3/CLK500
Send a message via AIM to kwlaznkid Send a message via Yahoo to kwlaznkid
no dont' think so, the flash is just to get rid of the "light out" signals, if it doesn't light up you probably have other problems, ie: broken bulb, bad ballast etc..
check all your connections again
Need angel eyes or any lighting stuff installed in LA? PM me, cheapest around, I promise
BMW E93 M3
Mercedes Benz CLK500
BMW E46 M3 (SOLD) BMW E92 335I (SOLD) Porsche 996 911 C2 (SOLD) BMW E46 325Ci (TOTALED) BMW E92 328i (SOLD) BMW E64 650I (SOLD)
kwlaznkid is offline   Reply With Quote
Old 07-27-2006, 06:17 PM   #5
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Yep it is a completely plug and play install. Whether you retrofit OEM xenons or aftermarket xenons you will have to get the ECU flashed to remove the bulb out warning.
You can remove Fuse 32 on pre-01 cars, however I recommend you get the ECU flashed for the most complete solution.
You may want to look into our Projector46 kits which can be equipped with preinstalled angel eyes and xenons set behind an OEM quality projector. It will be a xenon setup just as if it came from the factory. The install is 100% plug and play like an OEM setup and features a full lifetime warranty.
The kicker is that for less than the price of a used set of OEM xenons, you can get a brand new warranty backed set that IMO looks better than stock xenons
http://jlevistreetwerks.com/store/pr...95d93844ad512e
Old 07-27-2006, 06:25 PM   #6
JAe46
My Ride: 2003 325ci
if i try to connect the oem tommorrow and they dont work would the h7 xtec 8k from bimmer blvd work for the headlights? ive gone to shops trying to connect the xtecs but the shops dont want to because they say i could only use oem and they dont want to put those in thats why i got the oem from my friends m3..
Old 07-27-2006, 06:29 PM   #7
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Unfortunately not. OEM xenons take D2S bulbs. If they don't work you will have to narrow it down to the ballast/igniters or bulb.
Old 07-28-2006, 11:03 AM   #8
JAe46
My Ride: 2003 325ci
where do i get the computer reflashed?
Old 07-28-2006, 12:39 PM   #9
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Any dealer or independent shop that has a BMW MODiC/GT2 station.
Old 07-28-2006, 01:59 PM   #10
JAe46
My Ride: 2003 325ci
i got my headlights to light on but thet are flashing does that mean to reflash the computer?
Old 07-28-2006, 02:01 PM   #11
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
You may need a new Light Control Module (LCM) in addition to an ECU reflash. Try the reflash first then work on the LCM.
Old 07-28-2006, 02:08 PM   #12
JAe46
My Ride: 2003 325ci
do u guys sell the light control module? how much is it usually?
Old 07-28-2006, 02:51 PM   #13
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
We could probably get you one but the dealer is a better try. Check out realoem for part numbers and a rough estimate on price.
Old 08-04-2006, 01:38 PM   #14
JAe46
My Ride: 2003 325ci
today i finally got my car out the shop the xenon conversion done but my fogs dont work or my regular headlights they start to blink like crazy only until i put the high beams the xenons stay on with the highs any suggestions
Old 08-04-2006, 04:25 PM   #15
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
You just need to get our ECU reflashed to accept xenons.
Old 08-07-2006, 10:12 AM   #16
JAe46
My Ride: 2003 325ci
i flashed my computer today and the xenons work perfect but my fogs dont turn on i have xtec hids there the dealer doesnt know why they dont turn on but if i made a seperate switch work for it would it work??
Old 08-11-2006, 01:16 PM   #17
JAe46
My Ride: 2003 325ci
any help?
Old 08-11-2006, 01:29 PM   #18
JCsE46
(oOO \ (||||)(||||) / OOo)
JCsE46's Avatar
My Ride: 03 E46 JB, 08 MBE350
Send a message via AIM to JCsE46 Send a message via MSN to JCsE46
hmm, maybe you need a new LCM switch???
JCsE46 is offline   Reply With Quote
