Old 05-02-2002, 05:35 PM   #1
shan22
My Ride: 325I
adjusting camber???
Need to adjust camber after installing UUC springs?
shan22 is offline   Reply With Quote
Old 05-02-2002, 05:39 PM   #2
jestr
is bester
My Ride: '02 Steel Grey 325i
  • You dont need to adjust the camber.
  • you can also contact rob@uucmotorwerks.com
  • or call UUC @ 732.398.0001
jestr is offline   Reply With Quote
Old 05-02-2002, 06:58 PM   #3
vinnymac
St. Louis BMW Fanatic
My Ride: 2011 335is
Send a message via AIM to vinnymac
You shouldn't have to...
the best way to find out for sure is contact UUC directly.
Good luck.
vinnymac is offline   Reply With Quote
Old 05-03-2002, 02:25 AM   #4
Jspeed
My Ride: '01 330i
Lowering a car with McPherson suspension will induce negative camber. Consider this a nice bonus effect to lowering the car b/c it will help the tires bite better during corners. If you didn't have negative camber then the body roll of the car would make only the outside edge of the tires contact the ground.
Jspeed is offline   Reply With Quote
Old 05-03-2002, 06:51 AM   #5
Tominizer
My Ride: none
Negative camber is ok.............. but sucks for a daily driver as you get un-even wear on your expensive tires. For a daily driver, try to ge back as close as possible to factory specs on the camber.
Tominizer is offline   Reply With Quote
Old 05-03-2002, 04:15 PM   #6
Jspeed
My Ride: '01 330i
Yap, I should add that for a daily driver I recommend no more than 1 degree of negative camber. If you track your car or auto-x often then 2 or even 3 degrees of negative camber would be beneficial.
Old 05-03-2002, 04:18 PM   #7
topazmania
Ogler of Women and Mods
My Ride: '01 M3 cab, '90 325i
Mmmmm. 3 degrees of neg. camber.
topazmania is offline   Reply With Quote
