£600 Coupe bargain... - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 07-22-2017, 07:49 AM   #1
Crez_UK
My Ride: 320i Coupe
Hello to all you e46fanatics
My name is Craig I'm a former VW lover who is now fully converted to BMW life...
Around two weeks ago I purchased my first BMW from my brother inlaw for just £600.. and so far it looks to be a bargain of a lifetime
The car:
E46 coupe 2.2L 2001
The car is in over all good condition but had a few minor problems:
- coolant leak
- two hand sized patches of lacquer peel n/s rear & o/s roof.
- Leaking Cam cover
- Loud O/S rear wheel bearing
My first job was fix the coolant leak & from my research online a full refit of the cooling system was a must anyway. I found that the radiator had collapsed the dam thing look like a banana at the bottom! I have now replaced the water pump, Expansion tank, thermostat, belt and noisy tensioner while the radiator was out, The car now holds coolant just fine..
Next jobs are to replace the rear wheel bearing, Then a oil and plug service along with the cam cover gasket & Vanos seals.
I've driven the car arorund 1,000 miles since my ownership I can't believe I have spent so many years without a BMW in my life I love it..
Ive spent a lot of time researching online about the car and their problems. But If any of you kind users can point me of other parts to check/service I would be truly thankful
Here to stay & kind regards
Craig
Crez_UK is offline   Reply With Quote
Old 07-22-2017, 08:21 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Welcome Craig. Congrats on the BMW and good job doing the work yourself.
Old 07-22-2017, 08:27 AM   #3
kirmanj muzoori
My Ride: 1999 bmw 323i e46
Good that u replaced the entire cooling system. Make sure u bleed the system properly.
How many kilometres is the car?
Get a code reader online, or get the codes read by a mechanic. This way you stay on top of everything and know when something is wrong.
Check the transmission oil, some bmw owners thought that the fluid was "lifetime" and neglected it. Replacing the fluid obviously helps extend the cars life.
Test the battery and alternator to ensure the car is getting adequate voltage. Bmw's require a lot of voltage so low voltage causes all sorts of issues.
£600 is really cheap for the car. Overall the e46 is a really comfortable car to drive but there could be a lot of issues if not maintained well.
Sent from my SM-N9005 using E46Fanatics mobile app
kirmanj muzoori is offline   Reply With Quote
Old 07-22-2017, 10:08 AM   #4
Crez_UK
My Ride: 320i Coupe
Hi kirmanj muzoori
the car has just clocked 120,000 miles.
I let the car come upto temperature & ran the heater on full while bleeding the system.
I used to work for Hyundai I'm no longer in the trade & I fell out of love working on cars a while back.. but the BMW has brought it all back to me & I have found myself enjoying the work during my days off
Thank you for the comments I will be sure to add them to my list
Old 07-22-2017, 10:10 AM   #5
Crez_UK
My Ride: 320i Coupe
Hi Soildjake thanks for the warm welcome ***128077;***127999;
Old 07-22-2017, 10:33 AM   #6
bendoscopy
My Ride: 02 320Ci (M54 2.2)
Welcome, fellow Brit.
Another 2.2/coupe here. Similar mileage too.
bendoscopy is offline   Reply With Quote
Old 07-22-2017, 11:04 AM   #7
kirmanj muzoori
Hey Crez, did u by any chance unscrew the plastic bolt near the cooling system. It helps to get rid of some of the trapped air. They outline it in a few YouTube videos.
Old 07-22-2017, 12:38 PM   #8
Crez_UK
My Ride: 320i Coupe
Hey like your style where are you from bud??
Old 07-22-2017, 12:41 PM   #9
Crez_UK
My Ride: 320i Coupe
Yes I used the bleed value as you described.
Old 07-22-2017, 12:44 PM   #10
bendoscopy
Just outside of Guildford. What about you?
What colourís your E46?
Old 07-22-2017, 01:27 PM   #11
Crez_UK
My Ride: 320i Coupe
I'm located in Skegness, Lincolnshire
The car is Dark Blue with black leather not sure on the correct colour name just yet.. will post some pictures soon
What about yours?
Old 07-22-2017, 01:28 PM   #12
bendoscopy
What about yours?
Oh nice! Sounds good.
Iíve got topaz blue (which I guess is kinda a mid blue) and beige interior. I had my heart set on that combo and managed to find a decent model up in Birmingham.
Display Modes
