Old 08-08-2006, 06:02 PM   #1
TiAg2247
My Ride: E39 M5 | E55 AMG
2001 Coupe + LED w/ Resistors?
Does this do the trick without needing a LCM swap?
Want to put on LEDs in the rear of the 330Ci, its a 2001 model but from what I've read it will need a new LCM + reflash. Please tell me the resistors do the trick because I can't see myself spending money on a ne wLCM + reflash just to get the LEDs working.
TiAg2247 is offline   Reply With Quote
Old 08-08-2006, 06:09 PM   #2
FTLAUDM3
My Ride: M3, Z4
I just did LED's myself. I never heard of anyone using OEM parts and using the resistors. The resistors are used for aftermarket LED's. If your car is 9/01 (look on inside of door for date) or earlier you need a new LCM and reflash from dealer. If you go aftermarket, you can use a resistor pack and you don't need a new LCM or reflash. Just be aware the quality isn't OEM. Its close, but there is always drawbacks. Here is my post. Hope it helps and PM with any questions. I spent a long time doing my research. By the way, they are so worth it. Makes the car look newer looking and at night it looks cool.
http://forum.e46fanatics.com/showthread.php?t=389187
FTLAUDM3 is offline   Reply With Quote
Old 08-08-2006, 09:40 PM   #3
TiAg2247
Can I get a pic of the inside of the trunk?
edit: Oh and its build date is 07/00
Old 08-08-2006, 09:45 PM   #4
redwood77
My Ride: e46
redwood77 is offline   Reply With Quote
Old 08-08-2006, 10:20 PM   #5
woobiee
My Ride: JetBlack E46 323Ci
Send a message via AIM to woobiee Send a message via Yahoo to woobiee
i have a 2000 with OEM leds and with resistors....bypassing the LCM swap. Works fine
woobiee is offline   Reply With Quote
Old 08-08-2006, 10:39 PM   #6
brediv12
My Ride: Pista/e46
hm.. you just gave me hope.
brediv12 is offline   Reply With Quote
Old 08-09-2006, 02:40 AM   #7
freshprince2421
My Ride: 325ci
wtf i never heard this
freshprince2421 is offline   Reply With Quote
Old 08-09-2006, 01:01 PM   #8
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
I see no reason that the resistor setup wouldn't work with OEM LED's. The resistors just simulate a bulb and you wire them in parallel to the resistors so the LCM sees the full current. Obviously a new LCM with the right programming would be better, but it makes sense that you could just wire in resistors (find a good place to mount them, those suckers get hot).
If you need any help getting the parts gimme a buzz
Tyler@UniqueDesign is offline   Reply With Quote
Old 08-09-2006, 04:57 PM   #9
TiAg2247
Tyler, PM sent.
So in conclusion, throwing in the resistors withthe LEDs should work like a charm, yes? Could anyone who has done this install with the resistors show me pics of the inside of the trunk w/ the setup? Ie. resistor placement, etc.
