Old 08-09-2006, 01:30 PM   #1
330dirtydirty
My Ride: M3
Adjusting headlights after lowering the car
k im having some lighting issues... i just lowered my car and now my head lights points really low. i tried adjusthing from the knob in the back of the headlights and it seems fine but when i start driving the autoleveling kicks in and makes the headlight point down again. Anybody know how to adjust it so that the autoleveling doesnt make it go back to pointing low. I need Help! ASAP its pretty dangerous driving at night. thanks guys
330dirtydirty is offline   Reply With Quote
Old 08-09-2006, 02:04 PM   #2
BMW_Knight
My Ride: STG2 ZHP,E70 X5(DD)
Send a message via ICQ to BMW_Knight Send a message via AIM to BMW_Knight
Did you disconnnect the leveling arm for your zenons from the control arm?
Very common mistake.
Thanks to: www.getbmwparts.com www.aatuning.com www.toyotires.com
Eurowerkz Mid-Atlantic Regional Director
Join the Eurowerkz Facebook Fan Site : Click Here
Need your car coded with Euro Options? (Remote Windows up, Corner delete, DRL off, etc.) PM Me
BMW_Knight is offline   Reply With Quote
Old 08-09-2006, 02:06 PM   #3
330dirtydirty
My Ride: M3
umm not sure, how does that look like?
Old 08-09-2006, 04:19 PM   #4
BMW_Knight
Some of it is plastic and when you drop the suspension it breaks.
HEADLIGHT VERTICAL AIM CONTROL SENSOR
Old 08-09-2006, 04:44 PM   #5
330dirtydirty
My Ride: M3
so if its not that, would it be anything else?
Old 08-09-2006, 04:45 PM   #6
330dirtydirty
My Ride: M3
also are those sensor pretty obvious to see or is it fairly small?
Old 08-09-2006, 06:08 PM   #7
BMW_Knight
kind of small about as tall as a deck of cards. small enough I didn't see it when I did my suspension and I broke it. plus its black which doesn't help.
I would assume that if you didn't un bolt then odds are thats your problem
Old 08-09-2006, 06:19 PM   #8
330dirtydirty
My Ride: M3
how do you fix it?
Old 08-09-2006, 06:42 PM   #9
LeftCoastBias
My Ride: alpine white hotness
what if you did undo the leveling arm, and reattached it after installing the suspension?
will the auto-level figure out the new height they should point?
-JP
LeftCoastBias is offline   Reply With Quote
Old 08-09-2006, 07:59 PM   #10
BMW_Knight
yes because the suspension will be different and the leveler is setup so that if a heavy person gets in and that side of the car goes down it will level the lights according to the weight. When you lower it it works the same way. When I broke mine i turned the wheel all the way to the right and reached in to manually move the arm. I was then able to watch the lights move up and down. this is not a fix but its cool.
Old 08-09-2006, 08:10 PM   #11
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
You reaim the headlights to a new center, the autolevelling just keeps them at that center based on the cars tilt
You're spending a lot more time over here than you used to
Tyler@UniqueDesign is offline   Reply With Quote
Old 08-09-2006, 08:11 PM   #12
LeftCoastBias
good to know, i was thinking of going from sport to race springs (h&r) and i dont want to have my lights pointing in the wrong place.
now i guess i'll have to figure out what that part looks like and how to detach and reattach it.
-JP
Old 08-09-2006, 08:12 PM   #13
LeftCoastBias
kinda bored; summer is slow on the forums, so i spread it around a bit
-JP
Old 08-09-2006, 08:13 PM   #14
Tyler@UniqueDesign
Car Junky
It looks like a metal stray clamped onto an arm at the top and a ball joint at the bottom (on the control arm) really close the fender lining. Its on the passenger side IIRC.
Old 08-09-2006, 08:14 PM   #15
Tyler@UniqueDesign
Car Junky
So was the sale a fake then
Old 08-09-2006, 08:16 PM   #16
LeftCoastBias
oh for sure
people were *****ing about el supremo being my head moderator; and everyone had too much sand up their vaginas over him.
someone accused him of paying his way to the position, so we took it a step further.
-JP
Old 08-09-2006, 08:17 PM   #17
Tyler@UniqueDesign
Car Junky
oh for sure
I never had time to really look around, but saw your status was back as governor so I just assumed it was. Good joke, Gregg REALLY went nuts on that one.
Old 08-09-2006, 08:22 PM   #18
LeftCoastBias
yeah, if he's posting... he's whining.
-JP
Old 08-09-2006, 08:25 PM   #19
330dirtydirty
My Ride: M3
can someone take pictures of where this headlight control arm is at?
Old 08-09-2006, 08:28 PM   #20
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
It's located on the control arm. Here is what it looks like, courtesy of My330i.com
