Old 08-10-2006, 05:28 PM   #1
bombguy
bombguy's Avatar
My Ride: 2004 M3
Install help!!
Is the outer ring for the Pred. Chromiums suppoesed to sit at an angle? Also, where do you route the wires from the rings into the back of the headlight housing?
2004 JB
KWv2, Spacers 15/F-10/R, MVR Rep, Alpine IDA-X305 w/ KCE-BT400 Bluetooth,
Agency Power Exhaust, Khoalty AE's
bombguy is offline   Reply With Quote
Old 08-10-2006, 05:38 PM   #2
Ayamana
My Ride: 323ci
Send a message via AIM to Ayamana
no, its not supposed to sit at an angle. There are some threads covering your problem with facelifted sedans i think.. someone said either trim the headlight housing, or do not clip it in entirely. others just didtnt have a problem.. hope this helps. As far as routing the wires.. some people drill a hole.. there are some DIY's but i think there def. a way to get around drilling just not quite sure what it is.
Ayamana is offline   Reply With Quote
Old 08-10-2006, 05:53 PM   #3
bombguy
bombguy's Avatar
My Ride: 2004 M3
Yeah, itlooks like I'm gonna have to trim the bezel a bit. Thanks! I went ahead and drilled a 1/4" hole for the wires. Does anyone have a diagram for running the wires?
2004 JB
Old 08-10-2006, 06:32 PM   #4
Ayamana
My Ride: 323ci
Someones already done it
http://www.m3forum.net/m3forum/showthread.php?t=49641
Old 08-10-2006, 06:59 PM   #5
bombguy
bombguy's Avatar
My Ride: 2004 M3
Hmmm, what I'm trying to figure out is the brown wires with the male connectors go!!!
2004 JB
Old 08-10-2006, 07:19 PM   #6
bombguy
bombguy's Avatar
My Ride: 2004 M3
Alright everything works except for the "remote" function...any body got a clue?
2004 JB
Old 08-10-2006, 09:12 PM   #7
duffsabot
My Ride: (american spec) 325i
I may be wrong but from what I have read I think the brown wire is the remote kit. It runs trough the firewall and into the passenger floor light, That should activate the preds when you unlock the car with the light. should know in about a week once mine come in.
duffsabot is offline   Reply With Quote
Old 08-10-2006, 09:20 PM   #8
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
In order to make it not sit at an angle, you need to slip the ring on just BEFORE the first clip.
The brown wire is the remote kit, that is run through the rubber grommet in the empty compartment of your engine bay and into the glove box. From there you can drop down the glove box by undoing the 6 screws that hold it in and quick connect it to the red/blue wire of the footwell lights
Again this should all be covered in the install guide provided by your vendor.
Old 08-10-2006, 09:23 PM   #9
bombguy
bombguy's Avatar
My Ride: 2004 M3
Nick...thank you!! Umnitza told me to call ModBargains and they weren't answering. Soooo, thanks for the reply!!!
2004 JB
Old 08-10-2006, 10:08 PM   #10
bombguy
bombguy's Avatar
My Ride: 2004 M3
Got the instructions from Ron at ModBargains. Thanks for the help guys!! Also, thank you for getting them to me very quickly...ordered Monday and recieved today!
2004 JB
