Old 08-12-2006, 11:33 PM   #1
ChrisMT79
Here
ChrisMT79's Avatar
My Ride: 2015 AW M3/5GT
Crankshaft position sensor, E46?
It seems that about 90% of you do not understand the difference between the camshaft position sensors (which there are two, intake/exhaust). And the crankshaft sensor. (Ive done an extensive search). So does anyone have a good pic of where the crankshaft sensor is exactally? I've taken the airbox off and went under the car but cant seem to locate it.
Chris
ChrisMT79 is offline   Reply With Quote
Old 08-13-2006, 03:18 AM   #2
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
The sensor is located down from the starter neard the trans bell housing the sensor mount the the block tough to get in ther to see it is more a feel thing I doubt you will see it easily. good luck if you get stuck Steve's European is a good shop in michigan i used to work for them.
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 08-13-2006, 11:56 AM   #3
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
You have to remove the intake boot that connects the airbox to the throttle body in order to see/reach it.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 08-18-2006, 10:21 AM   #4
atomicgroove
My Ride: 2 BMW E46 Jeep TJ
Anyone have pictures of the location?
atomicgroove is offline   Reply With Quote
Old 08-25-2006, 11:43 AM   #5
burak_330ci
My Ride: 2000 e46 330ci
of course i have
pm me for the pictures...
burak_330ci is offline   Reply With Quote
Old 02-21-2009, 10:57 AM   #6
dondino
My Ride: e46 coupe
Most probably I have to replace this crankshaft sensor in my e46 coupe...N42 engine. Does anyone have a link or a document where explains how to do this job? Otherwise if someone did it already, can you explain how to do? I can see that in this old thread pics were never posted... do you have some pictures of the location?
Thanks for the help!
dondino is offline   Reply With Quote
Old 02-21-2009, 11:08 AM   #7
djnekkon
My Ride: MB3ci & z33 HR
http://forum.e46fanatics.com/showthr...t=elbow+vacuum
Old 02-22-2009, 03:22 AM   #8
dondino
My Ride: e46 coupe
Thanks djnekkon!
Much appreciated,
maybe do you have something also for the camshaft position sensor? Thanks.
Old 02-22-2009, 03:24 AM   #9
BMW_Stu
My Ride: HPF 330ci
I have pix. Look on my sig. I made a whole diy
BMW_Stu is offline   Reply With Quote
Old 02-22-2009, 12:55 PM   #10
dondino
My Ride: e46 coupe
Yes, i saw it... very well done thanks! And what about the 2 camshafts position sensors? Have you tried to change them? Do you know if there's a DIY? I searched but did not anything with pics...
Old 02-25-2009, 01:58 AM   #11
BMW_Stu
My Ride: HPF 330ci
i never mest with the cam sensors, from what i understand, its a relatively simple diy, i think u can do it without even getting your hands dirty. im not sure. study the pix on realoem.com. so you can see where its fastened and figure out how to remove it.
Old 02-25-2009, 03:27 AM   #12
Demon Eyes Kyo
My Ride: 2001 330i
Both the camshaft position sensors are easy to fix.
Intake Sensor is harder= 45min - 1 Hour
Exhuast Sensor = 15 min (easy)
The most important thing is make sure you have a good set of tools before starting and allow engine bay to cool down completely (to avoid getting burned).
[SIGPIC][/SIGPIC]
Demon Eyes Kyo is offline   Reply With Quote
Old 07-20-2011, 02:31 AM   #13
e46ers
My Ride: facelifted e46 n42
found this while reading blog.maybe help
http://lynxtx3.blogspot.com/2011/07/...sensor-on.html
e46ers is offline   Reply With Quote
