Old 08-13-2006, 09:24 PM   #1
b.d.racing
Banned
My Ride: 2002 325i
Passenger side inverter for CCFL's keeps going out. WHY????
Everything is wired up correctly, I think, and for some reason the passenger side inverter that both CCFL tubes plug into has gone bad on me twice now. I know this because both lights go out and then I replace the inverter and then a week later they're out again. Do I need a fuse or something?
b.d.racing is offline   Reply With Quote
Old 08-14-2006, 07:23 AM   #2
b.d.racing
Banned
My Ride: 2002 325i
Nobody has had this happen? This morning they were on then blinked on and off and now I think they're off again. Now that sounds like wiring but before they just wouldn't work.
Old 08-14-2006, 07:23 AM   #3
b.d.racing
Banned
My Ride: 2002 325i
Anybody have an idea?
Old 08-14-2006, 07:24 AM   #4
stapler12345
My Ride: Mineral White F30
who'd u buy it from?
Originally Posted by Penguin Koolaid View Post
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
Old 08-14-2006, 10:37 AM   #5
b.d.racing
Banned
My Ride: 2002 325i
A dealer on ebay
Old 08-14-2006, 11:11 AM   #6
ca1242
My Ride: 2003 330i
Check voltage going into the inverter with a voltmeter, maybe a loose connection. If you haven't already, solder all the connections, including the DDE wires.
Old 08-14-2006, 11:58 AM   #7
bimmerchop
My Ride: E46 M3
Maybe the inverter keeps getting wet in that specific area you have it placed. That happened to me before because my washer fluid tank kept leaking
Rich | Flickr | Instagram
- AW/IR 6MT E46 M3
- JB/B 5MT E46 328i
- Pearl Stg3+ B5 S4 (sold)
EURO.techniks
bimmerchop is offline   Reply With Quote
Old 08-14-2006, 03:59 PM   #8
b1218n
My Ride: BMW 325i, MR2 Turbo
I bought a set from EBAY about 1mo. ago and the original inverters went out. The first (driver side)I got a free replacement from the seller. The 2nd was behaving exactly as you described two weeks. The original inverters are from a company called racing dash. I don't think water ingress is the issue. I openned one the first bad one up and it's potted in RTV so it almost water proof (l also siliconed all the opennings when I first installed it because of stuff I read here).
I bought a pair of inverters from vibelights.com for $4.50 each. I had to mod/splice the connectors in as they are not the same as the original inverter. I just installed it this weekend so I can't say for certain it won't go again.
I measured the voltage using an Agilent benchtop DMM of the original inverter, +12vDC = 450VAC (when I reverse the polarity of the test probes I read 180VAC). The new inverters measure 450VAC regardless of the polarity of the test probes.
Hope this helps any.
b1218n is offline   Reply With Quote
