Old 07-25-2006, 10:13 PM   #1
xbluedr4gonx
My Ride: 2.5L I6
Fuse on Angel Eyes Keep blowing...
my angel eyes have gone out for a while now, the fuse keeps on blowing when i turn on the car. i checked the positive and ground they both seem fine. they were working for the past year or more that i've had it..then one day the fuse blew...and any new fuse i put in..it keeps blowing. any help would be greatly appreciated!!!
xbluedr4gonx is offline   Reply With Quote
Old 07-25-2006, 10:17 PM   #2
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Try changing the relay, that was my problem.
hi its me alec is offline   Reply With Quote
Old 07-25-2006, 10:32 PM   #3
xbluedr4gonx
My Ride: 2.5L I6
uhh how does that piece look like ? is it where all the T-tap thing connects, or where the fuse connects to everything else? where could i buy one ? thanks.
Old 07-25-2006, 10:45 PM   #4
happybmw
Are you happy
happybmw's Avatar
My Ride: 03' 325 XI
ok believe it or not a blown fuse can tell you alot of what's wrong.
Did is the fuse completely blown?? or did it just melt apart? if it's completely blown you most likely have a short to ground. if it's melted you have a low resistance/ high current problem.
happybmw is offline   Reply With Quote
Old 07-25-2006, 10:57 PM   #5
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
The relay is the black box with the bunch of wires coming out of it on the wiring harness. It could be a bad relay but your fuse blowing means you have a short SOMEWHERE. Check all of your connections carefully and make sure nothing is wet or making contact.
Old 07-25-2006, 10:59 PM   #6
CynicalWry
Doesn't like PMs...Email me
CynicalWry's Avatar
My Ride: 00 323i-05 cbr600rr
Send a message via AIM to CynicalWry
Water in the relay? pinched wire somewhere?
is your friend
Authorized Umnitza.com installer
301-825-5871
http://www.robinsNestChildCare.com - - - - - http://www.tntTint.net
CynicalWry is offline   Reply With Quote
Old 07-25-2006, 11:02 PM   #7
xbluedr4gonx
My Ride: 2.5L I6
i think the fuse looks more melted away than blown, but i don't know... when i turn on the car i hear a snapping sound and i'm pretty sure it came from the fuse...so blown maybe ??
all these things were working but the fuse just blew one day and it stopped working ever since.
Old 07-25-2006, 11:32 PM   #8
CynicalWry
CynicalWry's Avatar
search for a pinched wire...
is your friend
301-825-5871
Old 08-17-2006, 07:33 PM   #9
ayonae
My Ride: 330i 2001
I have the same problem too! I looked for a pinch wire and found nothing! What else could I look for?
ayonae is offline   Reply With Quote
Old 08-17-2006, 07:36 PM   #10
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
The ballasts are designed to also blow before, there is a built in short in there when they "die" - that's what is causing your fuse to blow.
Please email your retailer.
Old 08-17-2006, 07:47 PM   #11
Ayamana
My Ride: 323ci
Send a message via AIM to Ayamana
So i bought a set of Predators off a fellow fanatic and he mistakingly forgot to send me a piece. I think someone described it as a relay.. im not really sure what it is. Here is a pic http://www.umnitza.com/gallery/view_..._05_Image_0002
It is the black box thats bolted onto the car, i have the the wiring harness that looks like a cross but nothing to plug it into. What is this piece and where can i get another? my car is in pieces
Ayamana is offline   Reply With Quote
Old 08-17-2006, 09:25 PM   #12
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
You can pick one of those up at radio shack or home depot most likely. They are a simple 5 prong relay. We can also send you one but it will take a few days to get there.
Old 08-17-2006, 09:31 PM   #13
Ayamana
My Ride: 323ci
ohhh! awesome, thanks nick!
