Old 08-19-2006, 05:15 PM   #21
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Originally Posted by Clockwork View Post
2000 328Ci, I love how your fogs match your angel eyes. I have the angel eyes too and my fogs are just a bit yellower (if i can say that for sakes of a lesser word) than the angel eyes and my night light factory HID. yours match great.
thanks for the kind words ... cost an arm and a leg but was definitely worth it.
Timeless Motor Group
Old 08-19-2006, 05:17 PM   #22
Clockwork
My Ride: E46 (sold), E31, E53
now for looks purposes, i am wondering if i should purchase some 6000k HID D2R's to replace the 5000k ones. BUT i am trying to find out if I'll loose much in lumens quality and if it is really worth it.
Clockwork is offline   Reply With Quote
Old 08-19-2006, 05:24 PM   #23
donjuan45i
My Ride: e.quart.seis
You loose lumens, but gain the temp, which looks better. If the amount of light on the road means that much to you, than I would just stay where you are at. But 6000k will still light up the road nicely, not really that much less, and most people can even tell a difference, but can tell that the difference in color.
EDIT: and most people CANT even tell a difference
donjuan45i is offline   Reply With Quote
Old 08-19-2006, 05:30 PM   #24
Clockwork
donjuan, thanx, i may buy the 6000k d2r's afterall then, if i wont loose too much light output, cause i do drive non lit highways everynight and i want the best visibility possible, but also want my lights all to match.
Old 08-19-2006, 05:35 PM   #25
donjuan45i
are your 5000k d2r also???
Old 08-19-2006, 05:47 PM   #26
koven
My Ride: 330Ci
get 6k.. look at my sig
koven is offline   Reply With Quote
Old 08-19-2006, 05:47 PM   #27
Clockwork
well i dont know if thy are d2r or d2s, since i got them in the 5000k prolumens kit from Jlevi
Old 08-19-2006, 09:21 PM   #28
sanyomats
My Ride: 00 328CI
2000_328ci....lights looks sweeetttt!!!
sanyomats is offline   Reply With Quote
Old 08-19-2006, 09:22 PM   #29
sanyomats
My Ride: 00 328CI
clockwork --- the lumens for
6k - 2900
5k - 3100
Old 08-20-2006, 01:27 AM   #30
2000_328CI
2000_328CI's Avatar
thanks man... its a full 6k kit...
As for the 6k losing light output, it definitely is true. My 6k headlights don't compare with my friends oem xenons in terms of light output... his definitely light stuff up a bit better... but, I like the way the blue tint looks on the ground as it gives everythign a whiteish look.. the oem lights still make things look a little yellowish.
I would go 6k if you can afford to drop the money just for a temp change...oterhwise, stick with 5k
Old 08-20-2006, 01:03 PM   #31
Clockwork
sanyomats, thanx for that info, and 2000 328Ci, thanx for the info on the 6000k compared to the 5000k. I believe i will stick with the 5000k HID. that is what i need, more lumens and light output, I guess I'll just have to sacrafice a bit of looks for practacallity.
thanx again gents
Old 08-20-2006, 01:11 PM   #32
2000_328CI
2000_328CI's Avatar
if you really want maximum light output, switch down to 4300... you will notice the difference. 4300 puts out the maximum amount of lumens which is why BMWs Mercedes and Lexus all use 4300 HID from the factory
Old 08-21-2006, 12:58 AM   #33
Mautofied
My Ride: 02 BMW 325Ci
2000 328Ci -- who did you buy your bulbs from? Thanks in advance
Mautofied is offline   Reply With Quote
Old 08-21-2006, 10:08 AM   #34
2000_328CI
2000_328CI's Avatar
www.jlevisw.com
his shop is the only one I will go to for all my lighting needs
Old 08-22-2006, 11:20 PM   #35
Mautofied
www.jlevisw.com
excellent- THANKS I will have to check them out!
Old 08-23-2006, 12:17 AM   #36
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
www.umnitza.com
look at the tutorial section.
