Old 08-24-2006, 10:17 PM   #41
crazy1323
My Ride: '02 330Ci
Send a message via AIM to crazy1323
Originally Posted by NickG View Post
That's completely untrue. If both compressor sections have the same efficiency at the same boost level, then both will heat up the air the same. Don't forget that centrifugal superchargers are merely belt-driven turbo compressors.
Belt driven is KEY there. The belt on all engine is located at the front of the engine. This means that a supercharger is out of the way of the exhaust path and has a good source of cold air flow.
Now look where a turbo is, RIGHT ON THE EXHAUST MANIFOLD, which reaches temps arround 1300 degrees with little to no airflow. I have a very very powerful turbo car, stage 4 Porsche TT, and on a dyno run if you turn the lights off you can see the turbos glowing red hot. I would love to see a supercharger do that. I also have a '71 charger with a weiand 8-71 blower sticking out the hood, after passes it is still cool enough to touch. So a turbo's intake temp will be much hotter witht the same boost pressure and same aftercooler.
'02 330Ci
A Bimmer, a Porsche, and an old Dodge, I am too lazy to list and update.
crazy1323 is offline   Reply With Quote
Old 08-24-2006, 10:22 PM   #42
OCswedishM3
My Ride: E63 AMG
Wrong...The turbo will create more heat alot quicker as full boost will be achieved well before redline...Let alone the turbo will be much harder on the car all together than a centri SC.
OCswedishM3 is offline   Reply With Quote
Old 08-24-2006, 10:24 PM   #43
OCswedishM3
My Ride: E63 AMG
Originally Posted by unvmym3 View Post
azevedo motorsports actually has teh first boosted s54 , stuffed in a wide body e30 m3 ..at 10 lbs makes mid 500's to the wheels .running aem ecu and converted to throttle cable ,
Not the first...there is a turbo in Greece that is pushing in the 700whp range and already has posted a video racing an R1 bike...and destroying it..
Old 08-24-2006, 10:49 PM   #44
HartgeM3Power
My Ride: 325 / 08 R6
Send a message via AIM to HartgeM3Power
where can this vid be found?
HartgeM3Power is offline   Reply With Quote
Old 08-25-2006, 02:15 AM   #45
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
I'm still impressed by the twin turbo 3002 that was in the roundel.
That car would have been fun to work on for sure
Tyler@UniqueDesign is offline   Reply With Quote
Old 08-25-2006, 08:00 AM   #46
NickG
My Ride: 2011 BMW 550i M-Spor
You're assuming that the proximity of the exhaust, and its related heat, is automatically transferred to the induction/cold side. Well it's not. The turbine housing does get hot, very hot. But between the turbine housing and compressor housing is the bearing housing. The bearing housing is cooled by oil, and often times water too. So VERY LITTLE of that exhaust heat makes it over to the compressor. Whatever does is insignificant (ie, maybe a couple of degrees increase in air temps).
Our S52 Stage3 car pushes 18psi. I have datalogs from the dyno sessions that show with 90 degF ambient temps, the charge temps are ~115 degF in the intake manifold during WOT/full boost. How does that compare with your 8-71 blower's charge temps??
Well, technically yeah. The turbo will create hotter air charge temps cause it'll be pressurizing the air 5-8psi in the midrange, while the centrifugal is only doing 1-2psi. You got me there....but I'd rather have the added midrange torque that the turbo provides over the centrifugal SC
That's the arguement used by vendors who want to push a centrifugal SC over a turbo. I can claim that the centifugal SC puts more wear and tear on an engine than a turbo, since it's constantly being driven by the crankshaft (a turbo draws no additional energy from the engine). And depending on the belt's installation method, may be adding a constant side load to the front of the crank, further increasing the failure rate.
Nick
For Sale: 2005 BMW 330i ZHP with Technique Tuning Stage1 Turbo Kit
NickG is offline   Reply With Quote
Old 08-25-2006, 01:43 PM   #47
funkyman
My Ride: 330ci,Mazdaspeed3
I thought the turbo took a far more higher toll on the engine without a doubt because of the enormous stress exerted on the engine block,the crank etc because of high boost levels,which brings us to the knocking question.Therefore engine compression must be somehow lowered i guess,to reduce it.The inline 6 cylinder is somewhat limited to a peak compression,but i can see the turbo as the only replacement for displacement on the BMW 6 cylinder.The advantage of the turbo is its immense torque which the supercharger can not even come close to at same boost levels.Hence the new 300hp 335i has some 40lbs more torque than an M3 though its 33hp less,allowing to hit 0-60 at exactly the same time and killing the M3 70-130 in top gear.We`re not concerned with cornering abilities for the time being as it is the least of our interest on a Highway dewel!!!!Heheheh.
funkyman is offline   Reply With Quote
Old 08-25-2006, 03:14 PM   #48
crazy1323
My Ride: '02 330Ci
Nick, i dont have an intake charge temps currently. I was mearly stating that after hard pulls, the turbos can glow red but supercharger is still cool to the touch. I know i would not want to touch my turbo after a hard pull which makes me believe that the intake charke is also hotter. Also, what kind of turbo are you running on the stage three with what kind of intercooler, any injection or spray bar? Those temps seem really low considereing only the airflow from a fan on a dyno.
'02 330Ci
Old 08-25-2006, 03:59 PM   #49
funkyman
Mert,Mert,Mert where the heck are you,hurry up geeza we don`t get paid by the hour.
Old 08-25-2006, 07:20 PM   #50
unvmym3
My Ride: your daughter !
oc , i just saw that car you speak of in athens last month while i was over there , its actually a 316 shell and they stuffed the s54 in it , witha autronic standalone. with the juice that car is less powerfull then azevedos car .
unvmym3 is offline   Reply With Quote
Old 08-25-2006, 07:24 PM   #51
unvmym3
Nick G , good to see you over here shedding your wisdom bro.
Old 08-28-2006, 07:37 AM   #52
NickG
You have to realize that it's not the entire turbo that's glowing red. It's ONLY the turbine housing. The compressor housing is made of aluminum and can't get that hot (otherwise it would melt).
The car in question was running a GT35R turbocharger with a .50 A/R T04E compressor housing. The intercooler was our standard Stage1/2 unit (20x9x3 tube and fin core), with a mid-size fan on the dyno. No type of spray was used on the intercooler during the dyno pulls. Air temp logs done on the street showed similar results.
Nick
Old 08-28-2006, 07:38 AM   #53
NickG
Thank you sir
Nick
Old 08-30-2006, 08:46 PM   #54
GBX330ci
My Ride: 2011 Cayenne 6sp
Send a message via AIM to GBX330ci
Thank you sir
Now when you going to do an e46 kit? I've got my car waiting and it can be at George's in a heart beat!
GBX330ci is offline   Reply With Quote
Old 08-31-2006, 07:50 AM   #55
NickG
Your comment has been noted
Nick
Old 08-31-2006, 02:45 PM   #56
beemerfreak
My Ride: E350 Sport
http://forum.e46fanatics.com/showthread.php?t=382989
beemerfreak is offline   Reply With Quote
Old 09-01-2006, 12:03 AM   #57
funkyman
DA-Motorsports my ass i say,full of cr............ap and the crap is right here in E46 fanatics.
Old 09-02-2006, 01:43 PM   #58
///M3-QTR
My Ride: IR M3
Any updates ?
///M3-QTR is offline   Reply With Quote
Old 09-02-2006, 02:02 PM   #59
///AaronJtun3d
My Ride: UBR M3AN vert!
need dyno vids pronto
///AaronJtun3d is offline   Reply With Quote
Old 09-03-2006, 11:04 PM   #60
iLLM3
iLLM3's Avatar
My Ride: Boosted M3 + G35
Send a message via AIM to iLLM3
Interested ins eeing where this goes!
RUF R-GT2
07 E60 M5
01 996TT RWD/Stage 2+ turbo SOLD!!
03 G35 Nismo Daily
02 500+ HP SC M3 SOLD
www.e46psi.com
iLLM3 is offline   Reply With Quote
