Old 08-25-2006, 06:52 PM   #1
Chr325is
Chr325is's Avatar
My Ride: 325i
Testing Predator Chromiums
I did a search on how to test the predator chromium's but I didn't come up with much. The install guide doesn't mention anything either. How would I go about testing each ring? Can I just hook them up to a 12V source? What about a 9V battery? It would seem to me that I need some sort of relay before hooking it up to a straight 12V source. Any input?
-Chris
2004 325i 5MT ZSP
Mods
KW V1, H&R F/R Swaybars, Rogue Engineering RSMs, Meyle HD FCABs,
M3 RTAB with Rogue Engineering Shims, UUC Motorwerks Evo3 SSK, ECIS Intake,
Vorsteiner CF Console, 20% Tint, VMR 18x8.5F 18x9.5R CSL Reps
MTech 2 Front Bumper, M3 Steering Wheel.
Chr325is is offline   Reply With Quote
Old 08-25-2006, 11:00 PM   #2
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
You connect the rings to the inverters and get the inverters 12 volts in the proper polarity (the inverters can be damaged if connected wrong). Black/brown are usually grounds on the inverters. The rings operate at a few hundred volts AC. A9V battery would probably work, but you can just use your car too
Tyler@UniqueDesign is offline   Reply With Quote
Old 08-26-2006, 10:44 AM   #3
Chr325is
Chr325is's Avatar
My Ride: 325i
Cool man, I'll give that a try, thanks
-Chris
2004 325i 5MT ZSP
Mods
