Old 08-26-2006, 11:25 AM   #1
paul-w
My Ride: 330ci convertible
footwell lights
When my interior light comes on the passeger side footwell lights up but the drivers side footwell doesn't , is this normal or have i got a bulb gone if so where is it located , thanks.
paul-w is offline   Reply With Quote
Old 08-26-2006, 12:10 PM   #2
paul-w
Ok forget the first post ive done a search and found the answer but now i want peoples opinions please , do i change all my interior lighting to xenon white or blue , ive got a blue 330 convertible and think the blue bulb would look cool , what do you all think ? .
Old 08-26-2006, 12:45 PM   #3
lnkprksoldier
My Ride: Benz 300e
To make it worthwhile... Make sure the bulbs are big enough to hold up to 9 leds because if there are less, the output would be less compared to halogen. I say go with bright/super white and not blue. You will most likely need resistors because the bulbs require less power than halogen bulbs and if the car has it.. will show that a bulb is out.
lnkprksoldier is offline   Reply With Quote
Old 08-26-2006, 01:47 PM   #4
Devonjordan
My Ride: e46 325i
I bought these..... http://www.autowerks.com/xcart/custo...cat=314&page=1
I think they look great with my topaz blue, but the light is a lot dimmer than stock, so if you get it dont expect to read anything in your car.
Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
Devonjordan is offline   Reply With Quote
Old 08-27-2006, 09:50 AM   #5
paul-w
Thanks for the advice ,
Old 08-27-2006, 12:57 PM   #6
Two Outtakes
My Ride: is on 20" DPE's
i heard that most interior lights are no where near the brightness of the stock bulbs
RETIRED EP Sedan
Two Outtakes is offline   Reply With Quote
Old 08-27-2006, 02:05 PM   #7
mfanatic325
My Ride: '01 911 Turbo
the bimmian "xenon-look interior lighting kit" is better than the xynergie one in terms of output, but yes, it's still not as bright as stock...but the color IS much better to look at...I had the bimmian kit in for a while, then I decided to get blue LEDs to match my angel eyes at night
mfanatic325 is offline   Reply With Quote
Old 08-27-2006, 02:33 PM   #8
sillieidiot
My Ride: '06 AW 330ci
yea most interior xenons just make the cool blue color. i think LEDs are actually bright, been thinking about getting those
Old 09-14-2006, 11:07 PM   #9
devedean
My Ride: 323i
Paul-W,
I have done searches on this forum for the fix to the driver's side footwell light not comming on but haven't found anything. Can you tell where to find the fix? Is it a fuse? I checked the actual bulb and it has not burned out.
Thanks!!
2000 323i
devedean is offline   Reply With Quote
Old 09-14-2006, 11:11 PM   #10
mfanatic325
maybe try disconnecting the plug, and replugging it back in? or check to make sure that on each side of the bulb, the metal is touching, to close off the electrical circuit?
Old 09-16-2006, 09:40 PM   #11
devedean
My Ride: 323i
I check the bulb contacts and have unplugged and plugged the unit with no change. Is there a fuse specific to this drivers side light? The passengar side vanity mirror light doesn't work either. Any relation?
Old 09-16-2006, 11:09 PM   #12
sillieidiot
may be try taking the unit from the passenger side and connecting it with the drives? the whole unit itself could be the problem if you didn't already check that.
Old 09-17-2006, 10:20 PM   #13
devedean
My Ride: 323i
Yup, I'm an idiot. It seems that the most obvious solution to the problem was the fix. I replaced both the driver's side foot well light bulb and the passenger side vanity mirror bulb and viola, it works. I guess it's not easy to tell just by looking at them. On a side note: 1 set of 2 bulbs from Kraigan cost $6.50 times two sets/sizes for a total of $13 for 4 little light bulbs! What's up with that?
Old 09-18-2006, 12:00 AM   #14
mfanatic325
LoL...well, at least it's working again ...I have LEDs in most of my interior lighting areas...I heard it can mess up our lights <=[ ...but we shall see
