Old 03-17-2007, 05:24 PM   #61
PYRITE
My Ride: 1965 Ford Mustang
THIS THREAD MUST BE ARCHIVED WITH IMAGES HOLY CRAP :bowdown:
PYRITE IS SOLD!!
Welcome "KRYPTONITE"...
PYRITE is offline   Reply With Quote
Old 03-25-2007, 04:44 PM   #62
SammyV
My Ride: CB M3
Send a message via AIM to SammyV
any update on getting SES and transmission fault light fixed?
SammyV is offline   Reply With Quote
Old 03-25-2007, 07:43 PM   #63
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
Did your shop unplug the EGS Module? If not that might be why you are getting a tranny fault code?
I know this, when I plug in my EGS Module I get:
2 Hard Tranny fault codes due to the Cars computer looking for the auto tranny, but if I disconnect EGS I get:
1 Fault code P0600 - Signial Miscommunication error (I think related to the DME) Also DSC and Cruise Control are deactivated) It could also be a CAN bus issue for I beleive DSC resides on that bus as well and may need recoding.
I haven't done anything with my car lately for my brother hydrolocked it, and its just been sitting in my shop and I just pick away at it.
Hopefully by spring I will get all the computer work sorted out.
Jared
Ivegotissues666 is offline   Reply With Quote
Old 03-26-2007, 06:28 AM   #64
SammyV
My Ride: CB M3
I believe its 2 codes, I need to pickup a code reader to really know for sure, I would rather the 2 hard tranny fault codes then having DSC and cruise control deactivated, hopefully you can figure out and get to the bottom of this issue!
When the car was switched to manual software i do not believe there was a donor car involved, my shop has a programmer, not a gt1, something else, and was able to switch to manual settings, and car was brought to dealer to have them double check and recode the car for manual prior to having the ECU reflashed by active for my supercharger
Old 03-26-2007, 11:27 AM   #65
SammyV
My Ride: CB M3
where is the EGS Module located, I want to try unplugging it and seeing how the car responds, thanks!
Old 03-26-2007, 05:08 PM   #66
Ivegotissues666
It in the engine bay in the ECU box by the drivers side. It have 3 plugs coming out of it, I beleive the color of the plugs are blue, I have a picture and if I get a chance I can host it later.
Jared
Old 03-27-2007, 07:08 PM   #67
SammyV
My Ride: CB M3
Jared
please upload that picture, thanks again for all the help Jared! you have been extremely helpful
Old 03-27-2007, 10:18 PM   #68
Ivegotissues666
Here in this picture it's A7000, there should be 3 blue plugs that all connect to the EGS module which you shouldn't need anymore.
Jared
Name:	egs location.JPG
Old 03-28-2007, 12:26 AM   #69
SammyV
My Ride: CB M3
do you really know the reason why the DSC turns off when you disconnect these three plugs? If they are no longer needed, why does DSC disable, shouldnt this have been taken care of if the car was "programmed for manual" at the dealer?
Thanks again for the pics/help
Old 03-28-2007, 12:50 AM   #70
BMWPower06
BMWPower06's Avatar
My Ride: ///M5 & VW Group Car
Send a message via AIM to BMWPower06
damn most of the pics r gone
Sold: ACS 330Ci :(
BMWPower06 is offline   Reply With Quote
Old 03-28-2007, 07:28 PM   #71
bmw_chuzo
My Ride: HPF M3
Send a message via MSN to bmw_chuzo
the pics are still there, you just need to refresh your internet explorer .. It works for me
bmw_chuzo is offline   Reply With Quote
Old 03-28-2007, 07:32 PM   #72
bmw_chuzo
My Ride: HPF M3
I think the DSC/ASC/ABS needs to be reprogrammed also.
Old 03-28-2007, 09:21 PM   #73
Ivegotissues666
Exactly
SammyV: Your shop/dealer probably didn't take this into account for they didn't disconnect the EGS Module I'm assuming?
Jared
Old 03-30-2007, 11:15 AM   #74
SammyV
My Ride: CB M3
the EGS is still plugged in, I unplugged the three blue plugs, and sure enough the SES is gone, the tranny indicator light is still lit, and the DSC is now off, so i went ahead and reconnected it, I would rather have DSC and a SES light for the time being... I wonder what needs to be reprogrammed in the DSC/ABS?
You would think the dealer would know what the fk needs to be done, but of course, they are unwilling and useless when it comes to mods like this..
Old 03-30-2007, 06:01 PM   #75
Ivegotissues666
Not exactly sure, but probably something to do with the DSC/ABS Module looking for the EGS Module which theoretically wouldn't be there anymore considering there is no auto tranny. So probably some more coding thats different on Manuals than Autos.
If I had the neccessary equipment I'm sure I could figure it out, but unfortuantely I don't. Probably the only other solution other than coding would be to get the DSC/ABS Module replaced by one from the same year car only 5 Speed.
The tranny out indicator should be disabled if your shop had coded the ZCS (Body Electronics) Module I beleive. I know my shop took care of mine.
Jared
Old 04-02-2007, 01:44 PM   #76
espn9987
My Ride: BMW 330i
any new news on the software issues?
espn9987 is offline   Reply With Quote
Old 04-10-2007, 12:12 PM   #77
SammyV
My Ride: CB M3
bump ^^
Old 05-02-2007, 02:16 PM   #78
SammyV
My Ride: CB M3
any updates on the programming SES light issue?
Old 06-03-2007, 02:35 PM   #79
chelseyasc
My Ride: 323i AC Schnitzer
Send a message via Yahoo to chelseyasc
did you use the same driveshaft, master cyl., can you use the auto trannys flywheel, and your saying i can still use the auto trans. radiator still. werent the headers on the autos different from manual. i'm curios my tranny gave out and have money saved and might go with the 5 speed swap. also will i need a new rear end(differential)..... thanx............
chelseyasc is offline   Reply With Quote
Old 06-04-2007, 06:46 PM   #80
Ivegotissues666
1. Brake Master cylinder is the same for both auto/manual, you need a clutch master cylinder however.
2. Driveshafts are different autos are shorter so you will need a manuals.
3. No you cannot use the autos flywheel.
4. Yes you can still use your radiator, you just need to swap out the mounting plate thats different for a manuals for it doesn't have the trans cooler hoses connected to it and you need a new radiator drain plug adaptor peice I think the new one is longer (It's either longer or shorter forget which)
5. No the exhaust manifolds (Not headers) are not different between the same model car.
6. Just keep your shorter geared final drive of 3.46 since you have a 323ci right? If you don't like it, there are plenty of people on the forums who would most likely swap with you.
Jared
