Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Rating:
Display Modes |
#1 |
AM / FM Antenna Amplifier upgrade DIY (when replacing 99-01 radios with 02-05)
Background:
This is a DIY for those who have upgraded their 1999 – 2001 radio head unit to the 2002 – 2005 style. The 99-01 HU’s were made by Blaupunkt and the 02 – 05 radios were made by Alpine. Many people have swapped 02+ radios into their 99-01’s to take advantage of the increased functionality of the newer style radios (Sirius, AUX input, OEM iPod adapter). NOTE: Sirius requires an 03+ radio. Anyhow, the one caveat of doing this is a noticeable loss in AM / FM reception when putting the newer HU’s into the older car’s. The reason for this is because in 2002, BMW changed the type of antenna in the car (NOTE: In all coupes / sedans the antenna is in the rear window—it is not the shark fin or the bee antenna). The older style HU’s have 2 antenna connectors on the back of the radio, and the newer radios only have 1. There is an OEM antenna adapter available that converts 1 of the 2 adapters, allowing basic connectivity of a newer HU to a 99-01 car. The unused wire (I believe) is used to power something known as the antenna amplifier, which is located in the rear driver’s side C-Pillar. Without that wire connected, there is a significant loss of reception in the AM / FM radio. Solution If you want to upgrade to the newer style radio and not suffer any radio reception loss, you must replace the antenna amplifier in the rear C-Pillar. This amplifier also is responsible for the keyless entry in the car, so you may benefit from increased range with the new amplifier as well. Important: There are 2 different frequencies used for the keyless entry system (315 MHz and 433 MHz). You must first determine which frequency you have before you order an new amplifier. Luckily, your existing amplifier is stamped with the current frequency, so you simply need to pop the C-pillar off and do a visual inspection to determine which part you need to order from the dealer. Here are the relevant part #’s for the new antenna amplifiers: 433 MHZ 65256906074 315 MHZ 65256906075 And the link to them on realoem.com: http://www.realoem.com/bmw/showparts...81&hg=65&fg=30 OEM Antenna adapter: ![]() Comparison of Old vs. New antenna amplifier: ![]() Once you have ordered the proper antenna amplifier (circa $200 from the dealership), installation is pretty easy (takes about 20 minutes). You’ll need a flat head screwdriver and a T20 torx screw driver as well. If you can find a stubby T20 torx, that would be very helpful, as the screws are at a hard angle to unscrew. Step 1: Remove map light. Gently fit a thin flat head screw driver on the top of the map light and pry it out. It will pop right out. Disconnect the light and set it aside. Step 2: Remove C-Pillar. Its actually easier than it looks. Just reach your hand into the opening where the map light is, and pull. There are 2 plastic pieces holding the C-Pillar on. They should give way, then pop out. Instructions from the TIS on removing C-Pillar: ![]() Step 3: Remove old antenna amplifier. Use the T20 torx screw driver to remove the old antenna amplifier. I didn’t have a stubby torx, and was unable to unscrew the bottom screw, but was able to break the bracket off by bending the amplifier back and forth a few times. No worries, as the one screw holds the amplifier in just fine. Once the amplifier is unscrewed, unplug all the connectors. ![]() Step 4: Connect the new antenna amplifier. I found it easiest to connect all the wires first, then screw the new amplifier into the car. You will notice that there is an extra wire now (this is the wire that powered the older style amplifier that terminates at the HU. It is OK to just tuck this wire under the rear deck. This wire is now connected to nothing at both ends. ![]() Step 5: Verify that everything works. Turn the car on and make sure that both AM / FM radio work. Turn the car off, and verify that the keyless entry works as well. Once everything is tested, simply push the C-pillar cover back on, reconnect the map light, and you’re done!
![]() 2004 330i ZHP (me) 2006 X3 (wife) 2004 325xi (sold) 2001 325i (passed on to DavidJay) MY DIY write-ups MY Garage (all the mods) |
#2 |
Most excellent write up! I like lots of pictures!
![]() We have very noisy reception with AM in the stock '99 business radio. If I fiddle with the amp, it affects the performance. Listening to ballgames or talk radio is frustrating. Fortunately for me, this is my wifes car, so AM is a moot point, but I would like to know how to fix it. |
#3 | |
#4 |
Yeah, from what I've gathered since ownership about a year ago, BMW must of decided that a real functioning antenna was too ugly and they would rather sacrifice function to suit form. Good looking car = what radio? Morons.
#5 |
Mods please move to the audio form. Thx
#6 |
I had very bad reception on AM radio (ball games when living in LA) and then I took off the pillar cover next to the rear winshield driver side and tightened the antenna connector. It has been great ever since. 2001 325i with business radio
#7 |
OMG, I thought it was just my car that had crappy AM radio reception.
Great solution, except for the $200 part!!! |
#8 |
Banned User
Great write up sTEVE. you are becoming a PRO at BMW OEM DIY.
I upgraded my 2000 323i Business CD Player with a 2005 version out of a M3. All I did was bought the attenna adapter. I didn't suffer from any loss in AM or FM reception. All I did was make sure that the COAX cable was tightly secure by the amplifier. However, if I have problem in the near future I will take your advice and upgrade my amplifer all together. Great write up! I look forward to our future DIY collaborations |
#9 | |
Oh, I did a quick test while the antenna was unplugged. I had believed that this antenna amplifier may also be a compensator the Bluetooth phone cradle, so with the antenna unplugged, I snapped my RAZR into the cradle and turned the car on. The RAZR still had the improved reception of the external shark fin--so this amplifier definitely does not power the external cell antenna. ADA: While I have you on the line here... quick q regarding my tail light issue / bi-xenon headlight issue. I had my good indy shop look at wiring the bio-xenon's and they told me that the car would not take the programming because it was too old, so it would only take the programming for regular xenon's... Would it be beneficial to replace my ECU? That's the main computer that accepts the programming for the tail lights / xenon's etc, right? Wondering if I had that replaced if it might help. Anyhow, looking forward to your return to the states. Be safe overseas.
#10 |
Banned User
Don't mess with replacing your ECU for two main reasons:
1) Too expensive 2) Too complicated since the ECU is the brain of the car. You can still wire your bi-xenom headlights manually. It will just turn on with your regular high-beam H7. The high-beam xenon will still work (electronic flap) but it will work in conjunction with the H7 high beam. There was a DIY in bimmerfest about this. Basically a guy wired his electronic flapped to his h7high beam. If i can find the diy i will post it. good luck |
#11 |
Rolling on Dubs. Got Boost?
My Ride: AA SC Y2K 323i
Great DIY.... I still have my OEM 2000 cd player in for now and reception sucks cus of my tinted windows. I want to convert the roof antenna for my radio... I have to look into that more.
Charlie |
#12 |
great writeup!
#13 | |
I assume you are referring to Scott ZHP's instructions on biummerfest? Initially my indy shop tried wiring it that way, and discovered that the system would not take the programming. They then figured out that it could be hooked up, but as you said the bi-xenon shutter would be a flasher and the H7 bulb would come onin addition to the bi-xenon shutter on the high beam. I actually left it that way for a while, and unplugged the high beam.. I just turned it back the other day, since my indy installer guy said he was going to investigate how to hook it up properly. Also, I'd heard of people replacing the ECU on 04 cars so they could have Assist and Bluetooth (as opposed to just BT or Assist). I guess it costs about $900 to do the swap. Should a competent dealer be able to do this? Thx!
#14 |
Mom says I'm a catch
A lap dance is so much better if the stripper is crying.
#15 |
european auto source
Very good DIY - thanks for sharing your findings.
Tom G. | european auto source [eas] email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 | ca: 714.369.8524 x22 | fax: 714.908.1796 |
#16 |
Thanks Tom! BTW, I noticed that when the deforster is on and the AM radio is ON, there is no longer the static. That drove me nuts. Anytime I had the AM radio on with the defroster, I heard the loudest screeching static. Thankfully, that seems to have gone away with the new amplifier.
#17 | |
#18 |
Yep. Not to mention every baseball / football game etc is on AM... Drives me nuts that Sirius has football but not baseball. Baseball would be much better to have.. Most of the road trips in the summer , is when I listen to baseball... Football is only 16 weeks, and my butt is parked in front of the couch so, the Sirius football ius kinda useless for me...
#19 |
I have a 2001 330i with business cd. Considering that I dont use AM/FM radio; would it be safe to assume that if I simply plug a 2003+ HU in w/out ant adaptor/amp THAT the keyless entry and everything else will still work fine?
#20 |
My Ride: e46 323i, e30 325i
i just changed from 99 to 2006Feb HU without antenna adapter and everthing works fine except no radio signal.
and keyless entry system works good.
Done Hamann HM2 19' / Hamann Sturt Bar / Hamann Pedals / H&R Touring Cup Kit / K&N 63Series / DINAN Stage 2 / UUC SSK / Clutch Stop / 6000K Projector46 & Fog / Clear Corners / Interior Xenon Lights / OEM Alarm / 35% Tint / Painted strip, Kidney Grill with Trunk lip spoiler / Auto Dimming Mirror & Compass / 06 Deck with Aux Input / PhatNoise PhatBox Photo Subframe Story SOLD
