Old 08-28-2006, 12:46 PM   #1
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
Problem with angel eyes
Hi guys,
i was driving last night and i noticed that my angel eyes are not on ( reflection from the car infront of me ) the problem with it is that the wiring that goes to the battery is ripped. So the wire that actually powers the lights is stripped from that little circle thing that's hooked up to the battery and holds it, any ideas on how to fix this problem?
please help!
AMG-ETR is offline   Reply With Quote
Old 08-28-2006, 01:47 PM   #2
TrippinBillyFL
I might as well be dreaming
TrippinBillyFL's Avatar
My Ride: 2004 330Ci
Send a message via AIM to TrippinBillyFL
strip the wire and put a new ring terminal on it. make sure you crimp it well so this problem doesn't happen again. you can pick up a box of terminals for a few bucks at any hardware / auto parts store. make sure you get the right gauge for your power wire and large enough ring terminal to fit your battery.
TrippinBillyFL is offline   Reply With Quote
Old 08-28-2006, 02:48 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Yup you are just going to have to repair that connection. Nothing you can't pick up at Radio Shack.
Old 08-28-2006, 03:12 PM   #4
AMG-ETR
Hey guys,
thanks alot for all your quick responses, i changed the ring and for the hell of it i changed the fuse aswell, went to turn on my car and noticed that the angel eyes still dont work, looked at the fuse and the middle portion was disconnected/broken, so im guessing it keeps blowing fuses.
how do i fix this guys?
Old 09-01-2006, 10:29 AM   #5
Josh@AutoWerks
Past Site Sponsor
Josh@AutoWerks's Avatar
My Ride: E46 328ci
Send a message via ICQ to Josh@AutoWerks Send a message via AIM to Josh@AutoWerks Send a message via MSN to Josh@AutoWerks Send a message via Yahoo to Josh@AutoWerks
if it's blowing fuses then it's shorting out somewhere. Check your power wire to make sure there are no exposed wires that can be touching the body of the car. Also check all the wires leading into and out of the inverters for any damage to them that is allowing them to have exposed wires. Look at the little black connectors that connect to the ring wires and make sure they aren't damaged either. Im pretty sure you will find something with a little investigating.
let us know what you find.
Josh@AutoWerks is offline   Reply With Quote
Old 09-01-2006, 11:17 AM   #6
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
What size fuse did you replace it with?
Tyler@UniqueDesign is offline   Reply With Quote
Old 09-01-2006, 01:24 PM   #7
islanq
My Ride: An E46 like you...
Send a message via AIM to islanq
*Off topic* got any more pics of the girl in your sig up close?
islanq is offline   Reply With Quote
Old 09-05-2006, 12:09 PM   #8
AMG-ETR
5 amp
Old 09-05-2006, 12:29 PM   #9
Tyler@UniqueDesign
Car Junky
Originally Posted by kevin325 View Post
5 amp
Its something downstream of the fuse in the wiring then, maybe the wires near the inverter are able to short out or something? The inverters should each draw ~.5-1 amp, generally the lower end of this, but not all kits are the same.
