Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 08-29-2006, 09:57 PM   #1
TypeRvirus
My Ride: 04|325CI|ALPINEWHITE
Send a message via AIM to TypeRvirus Send a message via Yahoo to TypeRvirus
P0411 Secondary Air Injection System Incorrect Flow Detected
help i'm getting this cel, when it's cold out.. should i get another sensor unit or try to clean it? $? thanks in advance.
|BMW|04|325CI|ALPINEWHITE|30%TINT|ECIS|INTAKE|
TypeRvirus is offline   Reply With Quote
Old 08-30-2006, 02:26 PM   #2
TypeRvirus
Old 08-30-2006, 02:41 PM   #3
MITE46
My Ride: 323i
I'd check the cable to the air pump...and then check the o2 sensors...I hope that's right...=)
MITE46 is offline   Reply With Quote
Old 08-30-2006, 02:54 PM   #4
slow323ci
E46-free since 10-13-06
My Ride: 335i coupe
A failing/failed secondary air pump is a common BMW problem. I doubt it's any kind of sensor.
slow323ci is offline   Reply With Quote
Old 08-30-2006, 02:58 PM   #5
ian_clyde
whoo da daddy...
ian_clyde's Avatar
My Ride: 1999 318i SE
Send a message via MSN to ian_clyde
check the rubber hoses from the pump for cracking or holes....they sometimes wear with the 'dry heat' from the engine....it prob is the pump itself, but id rather take 2 minutes to check the hoses just in case as they are a hell of a lot cheaper..
.....i want to die sleeping like my grandfather...not screaming and shouting like the passengers in his car.....
ian_clyde is offline   Reply With Quote
Old 08-31-2006, 03:08 AM   #6
TypeRvirus
i look at the hose it seems ok, i'll double check it tho..
if the air pump fail how do i verify that? I just don't want to buy parts that will not fix the problem..
Anyone know if the emission controller unit has a longer warranty than normal? b/c i'm already at 58k miles.
thanks for your help.. damn bmw is a headache...first i worry about my step failing when it hits 100k now something else. money money money.. bmw = breaks my wallet...
Old 08-31-2006, 05:30 AM   #7
Commander FAT
Network Analyst
My Ride: 2002 330Ci
I'm pretty sure the secondary air pump is an emissions device. It might still be covered.
Because the B isn't for bling.
Commander FAT is offline   Reply With Quote
Old 08-31-2006, 01:39 PM   #8
TypeRvirus
called them, they won't covered it b/c it's over 50k miles..bmw eastbay wants 159.99 just to look at it... damn this suk
Old 08-31-2006, 02:02 PM   #9
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
ya..... don't you hate it when you take it to the dealer and go, "my powersteering is ouT" and they say okay we'll take care of it!
Come back later and they haven't done a single thing and wont cover it since aftermarket parts mumbo jumbo
and tell you to pay 160 inspection since some1 inspected it and found out the powersteering is out.
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 08-31-2006, 02:27 PM   #10
slow323ci
My Ride: 335i coupe
The air pump is an emissions device but only 3 major emissions devices are covered under the federally mandated 8 year, 80k mile emissions warranty - catalytic converters, the ECU, and the OBD system. All other components are covered under the regular 4 year 50k mile warranty.
Old 08-31-2006, 02:28 PM   #11
ian_clyde
whoo da daddy...
ian_clyde's Avatar
Thumbs Up
you can check to see if the pump still works...im not sure of the proper procedure..but its something like..you take the rubber hose off before u start your engine then start the engine..(the pump should come on for a minute or so then) you put your hand over the hole where u took the hose from and see if you can feel pressure building up....its something like that..i saw it on here, try doing a search for it though..
Old 08-31-2006, 03:31 PM   #12
MarvelPhx
www.my330i.com
My Ride: E92335i,04ZHP,99M3
Send a message via AIM to MarvelPhx
Actually, you have MS45 and that means you have a tiny MAF on your secondary air system. You can see it on the tube right after the filter. Check that first.
MarvelPhx is offline   Reply With Quote
Old 09-01-2006, 12:22 AM   #13
TypeRvirus
Here's a picture of that pump.. you 're saying to look at the MAF, how would i check if that's working? Remember i only get this code when it's cold at a cold start. I know i'm not the only one with this problem, i'm sure someone encounter this problem b4, pls help... thanks.
Old 09-01-2006, 02:57 PM   #14
TypeRvirus
ok, tested the air pump it seems to be blowing air, so i assume it's working. i also check all the vacum hoses, it seems to be ok.
Old 09-01-2006, 03:13 PM   #15
TypeRvirus
Federally mandated 8 year, 80k mile emissions warranty
thanks, i call bmwna and confirm that it's 8years 80k... so i'm taking it to eastbay bmw.. and i'll post what's wrong with it after they fix it... to keep you guys updated.. thanks again..
Old 09-01-2006, 07:15 PM   #16
slow323ci
My Ride: 335i coupe
THe ONLY things covered by the 8 year warranty are the catalytic converters, ECU, and OBD2 diagnostic system.
Old 09-02-2006, 03:10 PM   #17
TypeRvirus
should i just take it to them anyway.. and will i get charge for diagnostic fee? $159??? b/c this way at least i know wat's wrong with it so i can fix it.
Old 09-02-2006, 05:33 PM   #18
MarvelPhx
www.my330i.com
The 2ndary Air pump is part of emissions control and will be covered under emission warranty. Go to the dealer, it should be covered.
Old 09-03-2006, 01:20 AM   #19
TypeRvirus
wow. so many different answers, anyway i already schedule an appointment for this wednesday, so we'll c..
Old 09-14-2006, 10:39 PM   #20
TypeRvirus
Ok, Here's what i got from the dealer.. for code P1411.. btw it's not cover under emission... it's in your book..
They replaced the Vavle...
11727553064 - vavle list cost 138.45 got it for 89.95
11727514960 - Gasket list cost 6.50
