#1 |
My windshield washer fluid tank is leaking out all of it's water. I took the reservior tank out to investigate. The Strainer F Wash Pump (#7) is still glued tight to the bottom of the tank. I also took the washer pump out.
The washer pump(#6) is still operational as it sprayed fluid on the windshield, it was replaced 1 year ago. I've took the washer pump apart and put it back in one piece, and it stills works. I swore I tight it back into the Wash Pump base tightly. But overnight, all the water leaked again. So what do I do next, I don't know where the leak is exactly or what parts to replace; #6 or #7 or both or the tank? Any help! http://www.realoem.com/bmw/showparts...83&hg=61&fg=45 |
#2 |
Do you have headlight sprayers? Mine is leaking from there...
#3 |
My Ride: 01 330i Jet Black
funny... mine stated doing that today. Took it apart and found that it was the pump, theres a little hole which i think is for air to go into the pump so it functions, it was leeking out of this hole, I know this because I pluged it to see if I could rig it, doing that didn't allow the fluid to flow through the system, damn.... So I'll have to buy a new pump. Bimmerzone has them for around $22.
#4 |
Its the washer pump. Happens all the time. Just fork it over to the stealership and get a new one. Make sure you get the new gasket/screen with it.
#5 |
Can you explain the mechanics as to why the washer pump is the cause of the leak even though it's still operable and things look sealed and tight.
#6 |
Well the hole that fluid comes out as far as I can tell is for air to circulate into the pumping valve. If its working properly air would be sucked in, but then immediately seal itself to prevent a fluid leak in the reverse, after time this valve just gets wore out and begins to fail.
#7 |
Pump...
#8 |
#9 |
Replace the washer fluid pump...
#10 | |
exact same thing happend to mine, it would still spray but it leaked out of the little vent on the pump, i replaced the pump and the problem was solved |
#11 |
![]() Mine is also leaking fluid. Which number is for the pump. I do not have head lamp cleaning.
#12 |
If it all leaked out overnight then you need to push the washer/screen in tighter
![]() WTB: Black sun visors & grab handles - PM ME! |
#13 | |
like yesterday I saw a small blue puddle under the car and today nothing.
#14 |
hey i noticed coming home last night that my washer fluid is low as well.
Funny because i just got it back from the dealership where they did rear subframe inspection as well as brakes and oil and the sheet i got back says they also topped off the washer fluid. Which was low. three days later the light comes on again. I see no signs of a leak though. any ideas??? My warranty is up at the end of april. My luck the cars been bulletproof the last 2 years and as soon as the warrenty is up the problems start reeling in.... only have 48,000 miles by the way. |
#15 |
Then I would say the little air hole in your pump is bad and only working sometimes. The OP said his leaked out overnight so I would reinstall the pump and gasket to make sure it's in all the way.
#16 | |
That is what is funny about the washer fluid leak. The fluid has a rapid evaporation rate so it leaks out and dries up rather quickly. If it is a hot day or you drive alot you will almost never notice any fluid below the car or in the engine bay. Me and SolidJake looked at my tank today and I clearly saw it was leaking at and around the pump.
#17 |
mine was leaking at the connector between the headlight washer pump (pump #4 in the above diagram) and the headlights, so I pulled the headlight washer pump out and plugged the whole with a bolt. I think I gained 2 hp with the washer pump delete.
#18 | |
#19 |
Yea, its the pump. Mine did the same thing last year, and I remember reading a thread about it. I replaced mine and no issues with it at this moment.
#20 |
Quick question before I remove the tank how do I remove the fluid?
Did ya'll just let it all leak out before replacing/repairing the pump?
