Old 09-01-2006, 05:51 AM   #1
Niv`
My Ride: 325ci
Help with signal light bulbs! please!
Hi, I bought a pair of LED light BULBs (rear). Installed them but my dash board is reading it as a MISSING light bulb and is blinking really fast... in fact, the back up light bulb blinks with it. Is there anything I can do to get rid of this warning sign on my dash board? Please help. thank you
Niv` is offline   Reply With Quote
Old 09-01-2006, 10:48 AM   #2
Josh@AutoWerks
Past Site Sponsor
Josh@AutoWerks's Avatar
My Ride: E46 328ci
Send a message via ICQ to Josh@AutoWerks Send a message via AIM to Josh@AutoWerks Send a message via MSN to Josh@AutoWerks Send a message via Yahoo to Josh@AutoWerks
Im pretty sure some other vendors on this board offer them with resistors to eliminate that? Hopefully someone will chime in and let you know. good luck
Josh@AutoWerks is offline   Reply With Quote
Old 09-01-2006, 10:50 AM   #3
papa8856
My Ride: 2002 325i Jet Black
I had almost the same problem when I installed my clears I had A loose wire that was touching one of my brake light wires causing them both to blink check the wires in the bulb socket holder for melted plastic where they are touching I don't know if it the same problem but it doesnt hurt to look
papa8856 is offline   Reply With Quote
Old 09-01-2006, 01:08 PM   #4
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
You need to install resistors to equalize the power draw of the LEDs as compared with halogens. We have the correct resistors available here:
http://jlevistreetwerks.com/store/pr...48263c9f02e993
Old 09-01-2006, 04:08 PM   #5
Niv`
My Ride: 325ci
Thx Jlevi. How exactly do you install this? if it's simply plug and play I'll buy these. You gotta let me know how you install this tho. Thanks.
