Old 09-02-2006, 11:54 AM   #1
TrippinBillyFL
I might as well be dreaming
TrippinBillyFL's Avatar
My Ride: 2004 330Ci
Send a message via AIM to TrippinBillyFL
baking headlights
Hi all ... I bought some umnitza halos from mod bargains and they came in yesterday
Anyways, I have a facelifted coupe so I'm gonna need to bake my headlights. I have a convection oven and not a regular one. I know that I am supposed to cook food at 75 degrees lower than called for in normal cooking directions and reduce time slightly... do you think this goes for my headlights as well??? Will it harm the headlights if they are cooked for too long or too hot, even if it is just slightly too much?
TrippinBillyFL is offline   Reply With Quote
Old 09-02-2006, 12:54 PM   #2
TrippinBillyFL
My Ride: 2004 330Ci
Originally Posted by JonJon View Post
Unless your oven is from the 1900's. The computer in the oven automatically adjusts the temp ~ 25-45 degrees lower for you
why would it adjust the temperature??? It will cook at whatever temp I set it, I know this because I bake in it all the time (it is actually a oven at my business). What I meant is that if cooking directions call for 375 degrees they are usually refering to a conventional oven and not convection. convection ovens are generaly set at 75 degrees lower (ie: 300) and do not require preheating.
anyone ever use a convection oven for baking their headlights??? i'm gonna give it a try in a few minutes
Old 09-02-2006, 01:18 PM   #3
k3vkoh
My Ride: 330CiC
Send a message via MSN to k3vkoh
I heard that a hairdryer can get the work done as well, I don't know the details though, all I know is that you have to get the glue hot enough so you can get the headlight cover off.
04' BMW E46 330Ci Cabrio - Mod in progress...
k3vkoh is offline   Reply With Quote
Old 09-02-2006, 01:42 PM   #4
ADA
Banned
My Ride: 323ci
make sure you put some butter and oil so you don't burn the headlights. jk.
P.S. Make sure something in the bottom to prevent the headlight from melting through the oven's grill
ADA is offline   Reply With Quote
Old 09-02-2006, 02:31 PM   #5
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Just follow this guide and you will be golden:
http://www.jlevisw.com/Bake.pdf
Old 09-02-2006, 02:57 PM   #6
TrippinBillyFL
My Ride: 2004 330Ci
thanks guys... just got my headlights out and ready for baking... we'll see how it goes!
Old 09-04-2006, 03:27 AM   #7
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
good luck
BreakMyWallet is offline   Reply With Quote
Old 09-04-2006, 04:33 AM   #8
ADA
Banned
My Ride: 323ci
any updates?
