Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 09-04-2006, 06:15 PM   #1
jpr
My Ride: '99 323i
OEM Damper Trivia
Here's some interesting things I found out while poking around http://webcat.zf-trading.com/
Before 2001, there was basically 2 varieties of OE dampers
*the standard suspension came with the Sachs "Super Touring" line of dampers with a parameter code of SFE32/22X122A on the struts
* the sport supension came with "Advantage" line of dampers with a parameter code of SFE32/22X96A on the struts
After 2001, there was a switch to 3 varities of dampers, all in the "Super Touring" line
* a standard suspension with a parameter code of SFE32X56A
* a sport suspension with parameter code of SFE32X86A
* and a "M-technics II" version with a parameter code of SFE32X96A - this is the ZHP damper
The M3, by the way, also uses the "Super Touring" dampers with a parameter code of SFE32X165A
I don't really know how to translate the parameter codes, but they are clearly related to shock internals and the degree of compression and rebond damping.
I also don't really know what the significant differences are between the "Super Touring" and "Advantage" line of dampers. But judging from the producte placement on the ZF website, I looks like the "Super Touring" is Sachs lower end product, the "Advantage" is their midline product, and the "Performance Sport" is the high end. As another bit of trivia, it is the "Performance Sport" line of dampers that comes in UUC's Stage 3 suspension kit. I also suspect that these are also the same dampers used in the Eibach pro-kit.
As for the OE dampers, it's clear that along with the other model changes in 2001, the damper selection also changed. It appears that there was an overall softening of the rates. I'd guess that the 323/328 "sport" suspension dampers are actually equivalent ot the 325/330 "m-technics II / ZHP" dampers. The 325/330 "sport dampers" probably fall somewhere in between the original standard and sport damper stiffness, and the 2001+ "standard" suspension is probably cushier than the 323/328 "standard" suspension.
jpr is offline   Reply With Quote
Old 09-07-2006, 04:22 PM   #2
jpr
My Ride: '99 323i
Here's the information I've collected, sorted two different ways. All data was taken from the ZF-Trading web site and cross-referenced with RealOEM. Send me an email if you want the Excel version.
just noticed a mistake in my first post - the damper parameter code for the ZHP/pre-2001 sport is ***98A not ***96A - same conclusion, but technical accuracy is always good
Old 09-07-2006, 04:28 PM   #3
Alex
Mom says I'm a catch
Alex's Avatar
My Ride: E46
Send a message via MSN to Alex
BIG if that is true.
A lap dance is so much better if the stripper is crying.
Alex is offline   Reply With Quote
Old 02-16-2008, 11:03 AM   #4
jpr
My Ride: '99 323i
Revisiting this subject again, I'm now pretty certain the the first number is a compression value and the last number the rebound value. Where you see two numbers on the compression side, such as 32/22, I believe that represents the high-speed/low-speed compression.
While I'm certain the numbers have at least a relative significance where higher means stiffer, I do not know if they have an absolute significance where a particular value correlates to a value on a dyno.
Old 01-17-2009, 04:30 PM   #5
Silver325
My Ride: 2002 325i
Very useful information, thank you for making those spread sheets available. I just received my replacement Sachs Super Touring struts and wanted to make sure they were the right ones. My car came with the sport package suspension. The spread sheet was key because the SFE32X86A number is not printed on the box or the new strut. The sticker on the strut is 290947 and 290948 for the other. Now I can install with confidence.
Meyle control arms, M3 RTAB's, Bridgstone Potenza RE760
Silver325 is offline   Reply With Quote
Old 01-19-2009, 12:22 AM   #6
jpr
My Ride: '99 323i
Glad to hear it came in handy - thanks for posting the feedback!
Old 04-27-2009, 09:08 PM   #7
Chomot
My Ride: Looking for BMW
This is great but I do not see the 325XI or 330XI listed. These two models are a bit of a rare bird suspension wise and I have one that needs struts and shocks. Do you have any info on what will cross to these? I am looking for a plush ride and the Billsteins everyone likes are concerning me.
Chomot is offline   Reply With Quote
Old 04-27-2009, 09:09 PM   #8
carbon323
My Ride: -
hahaha the 323 makes a comeback! jk, gl with info OP
carbon323 is offline   Reply With Quote
Old 04-27-2009, 09:14 PM   #9
B33MER
My Ride: 330i SMG M-Sport
Thanks for the info jpr ... much appreciated
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
B33MER is offline   Reply With Quote
Old 12-17-2012, 06:55 PM   #10
daki_bmw
My Ride: 330Ci
Bumping an ancient but extremely informative thread...I've got a question...
I need new front shocks and I am considering options...but I am not sure about one thing when it comes to Sachs (Advantage or Super Touring line). I have 2001 330Ci...check out this chart:
ST=standard, SP=sport, SF=sportfederung (lowering springs)
OK, I understand the OEM portion of it (ST and SP), BUT if one is to buy shocks for lowering springs setup, they say to use S (super touring) 556867 + 556868 shocks. This is the thing that buffled me. Super Touring line shocks are around 60% of the price of Advantage line shocks (for the similar car etc...) in my country at official Sachs distributor. I am asuming that stiffer shocks should be more expensive. On the other hand, when you look at "code numbers", for sport suspension Advantage shock (556874/556873) code is SFE32/22X98A, and the code for Super Touring (556867/556868) is SFE32/22X122A, and if jpr's logic is correct, it does make sense that they should be used for stiffer/lowering spring. But then again, why are they so cheaper?
Bottom line, in case you have lowering spring, would you go for Super Touring 556867+556868 shocks?
daki_bmw is offline   Reply With Quote
Old 12-17-2012, 06:59 PM   #11
tock172
My Ride: '12 135i Dinan S2
I would spring for a set of Bilstein sport dampers and call it a day.
Very interesting thread. So now we know that ZHPs had their own special dampers.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 12-17-2012, 07:12 PM   #12
trizzuth
My Ride: 231k, 16yr old B3AST
Bump for me to read later
trizzuth is offline   Reply With Quote
Old 12-17-2012, 07:28 PM   #13
daki_bmw
My Ride: 330Ci
Originally Posted by tock172 View Post
...So now we know that ZHPs had their own special dampers.
Can you point me to the part where you've come to that conclusion? Different part number - yes, but it is the same shock 556873/556874
Old 12-17-2012, 07:28 PM   #14
tock172
Right here, unless I'm reading it incorrectly.
Old 12-17-2012, 07:38 PM   #15
daki_bmw
My Ride: 330Ci
Aaaah, that....what jpr meant to say (he can correct me if I'm wrong) that it is the ZHP dumper, but what he didn't say is that exact same damper was used in a variety of applications, including 325Ci etc. etc....same exact dumper: 556874/556873. Check out the chart I posted few posts earlier. Or this thread (first post, last paragraph): http://forum.e46fanatics.com/showthread.php?t=398977
Old 04-13-2016, 03:00 PM   #16
Joe Quimby
My Ride: e46 330Ci
I have a 2001 coupe. Looking at the Sachs damper reference sheet it appears my car dame with the sports suspension with the Sachs Advantage dampers. Most parts houses will tell me the Super Touring line is what fits my car. I've searched up and down but is there any information available on what the actual differences in these two lines of shocks/struts are, or why BMW switched to Super Touring line dampers?
Joe Quimby is offline   Reply With Quote
