Old 09-04-2006, 10:12 PM   #1
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
Angel Eyes only work with the remote kit now.....
Well, I have had P46's for about two and a half years with the remote kit, and they have worked wonderfully. This week both rings on the passenger side stopped working, I thought it might be the ballast, but tonight I was poking around the wires and they lit up. So, I cut off the old connectors to the headlight and made new connections. That side works fine now, however, neither side lights up when the car is on, they only work with the car off, and using the lock/unlock with the remote kit. They do not come on when the car is running at all. I looked at the fuses, they are fine. I checked the ground, it is good. I took the relay apart and it looked to be fine. I have not opened the ECU to look at the tap yet, but some of the wires going into the relay look as if they have melted a bit, it might just have been dirt, couldn't tell.
So, anybody have any ideas on that? Should I try a new relay first?
how much is the new remote kit/wiring harness?
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 09-04-2006, 10:26 PM   #2
n3985
My Ride: E92 soon?
A new relay is approx $30, I would first disassemble the relay. It is simply a relay plugged into a socket, take it apart and start diagnosing!
n3985 is offline   Reply With Quote
Old 09-05-2006, 08:38 PM   #3
davidwarren
Halfway to 2L
My Ride: 2010 335i
It was the fuse. Blew it when I made the new connections.
