Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
Shock sensor warning signal!!!
I believe I have figured out how to get the stock alarm to have a warning signal. If the high sensitivity wire on the shock sensor is hooked directly to the input for the siren, it will sound the alarm only for the time that the sensor is activated. What the shock sensor does is simply connect the 12v power supply to whatever is hooked up to the sensitivity wires when it is rattled. hig/low sensitivity is fed 12v depending on the size of the shake.
With this method, if you bump into the car, the siren will go off for a brief moment, thus creating a warning. If the car is hit hard enough, the low sensity wire hooked up to the actual alarm trigger wire will trip the alarm. I need to find the input for just the siren that feeds into the general control module behind the glove compartment or anywhere near there. If anyone has the wiring diagram, I'd appreciate a little help here. Let me know if anyone has tried this. Thanks in advance! |
#2 |
shock sensor?
#3 |
are you talking about the tilt sensor?
![]() B l a c k . S a p p h i r e . M e t a l l i c . 6 4 5 c i |
#4 |
shock sensor that you can add on. I got mine from circuit city for $20. I believe it is a DEI 504D or something like that.
#5 |
My Ride: E90 / ATR-72
did you ever figure out how to do this?
