Old 09-10-2006, 01:05 PM   #1
Bowser330
My Ride: 2004 330ci
Dim chromiums???
I just put in my chromiums last night.
They are insane looking, love em.
They are not 6000K, but white and nice none the less. I put in 6000K xenoflo and those are 6000K white-violet, REALLY NICE.
One prob..... the driver-side halos are brighter?? could it be just the cheaply made connectors? I will try to debug, anyone else have that issue...?
I will post pics once i debug the problem.
Bowser330 is offline   Reply With Quote
Old 09-10-2006, 01:51 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Have you tried starting the car and revving the engine a bit?
Old 09-10-2006, 07:42 PM   #3
Bowser330
My Ride: 2004 330ci
i did drive around for quite a bit afterward. when you mean rev, is it necessary to rev the engine up really high?
Old 09-10-2006, 07:59 PM   #4
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
No not at all, just to get the alternator going.
Try swapping the ballasts to see if the problem switches sides.
Old 09-10-2006, 11:23 PM   #5
n3985
My Ride: E92 soon?
Make sure the connection from the power inverter to the rings are tight, as well as the the wires from the relay to the power inverters. Check the ground too, my friend's rings only lit up 1/3 of the way upon initial install, problem was a bad ground point.
n3985 is offline   Reply With Quote
Old 09-10-2006, 11:28 PM   #6
Bowser330
My Ride: 2004 330ci
can someone reccomend to me a good ground point??? i have my setup in the open space in the engine bay infront of the passenger side.
I have the ground attached to the same bolt as the HKE box, dont know if that could be an issue, it might be, i want to change the ground but dont know where...hmmm...
Old 09-11-2006, 10:53 AM   #7
Bowser330
My Ride: 2004 330ci
I found the culprit. broken pin in the el-cheapo connectors
