Old 09-11-2006, 12:08 PM   #1
MSC1
My Ride: E38 97
1999 323i Rear end/driveshaft clunking
I believe the flex disc is located under the center console It's not coming from there. It's coming from closer to the rear. I've had to replace center support bearings on E36's before but don't recall doing any on E46's
My question is, Is it common for center support bearings on 99 E46 with 120k?
Or is it common for the rear end to be bad?
You can feel play and some thuding sound when your in any gear and giving it pedal and letting off.
Any ideas? Center Support bearing? Bad rear end?
MSC1 is offline   Reply With Quote
Old 03-05-2008, 12:04 PM   #2
FiShDoG323i
My Ride: 2000 BMW 323i
same problem here, have you fixed it yet? i installed new springs,shocks,struts,mounts,and rear diff mounts, seen no visible sub-frame damage, and still have the problem you describe above. any suggestions .i think it could be a driveshaft problem.
FiShDoG323i is offline   Reply With Quote
Old 03-05-2008, 12:17 PM   #3
ixtoxi
My Ride: 02 330xi, 88 325iX
Drive shaft flex disc (guibo) or center support bearing.
ixtoxi is offline   Reply With Quote
Old 03-05-2008, 12:18 PM   #4
black323i
My Ride: 323i
by any chance, does this sound like what u guys are experiencing? ughhh these knocks are such a nuisance
black323i is offline   Reply With Quote
Old 03-05-2008, 12:20 PM   #5
Brinkley
My Ride: 99 328i, 07 z4 3.0
its probably your rear differential bushing
Brinkley is offline   Reply With Quote
Old 03-06-2008, 05:17 PM   #6
FiShDoG323i
no i changed the 3 rear diff mounts with meyle hd and 2 stock ones.
i hope this ain't the rear sub-frame going
Old 03-06-2008, 05:19 PM   #7
Brinkley
You got the big one in the rear? I seemed to have about the same issue as yours and it was the big rear mount. I would check it again just to be sure it isn't bad! Hope it's not your subframe man!
Old 03-06-2008, 05:21 PM   #8
GRIDLOCK
My Ride: E36 / E46
Time to get your ride up on a drive-on rack.
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 03-06-2008, 05:24 PM   #9
FiShDoG323i
i work at a dealership so the drive on rack is no prob, the big rear mount is only 1 month old and i installed it myself so i know it is not bad
Old 03-06-2008, 09:24 PM   #10
Brinkley
yea check the subframe man Good luck!
Old 03-07-2008, 05:56 AM   #11
mikeson
My Ride: 99 323I
it's not sub frame, mine is mint clean.
OEM xenon retrofit, Auto light/rain sensor DIY, OEM fog DIY,..........so many things DIY since 2000 :)
mikeson is offline   Reply With Quote
Old 03-07-2008, 08:58 AM   #12
FiShDoG323i
i talked with another tech at my shop he thinks that maybe the diff is getting sloppy (loose) internally and that the noise could be the gears banging together. i did notice that while driving last night if i tap the throttle while coasting around 40-60 i can make the noise happen more frequently, also when slowing to a stop when the trans shifts down into 1 st. gear i hear and feel the thud-clunk-bang-thump noise everyone talks about. i want this fixed but would like to do it myself. HELP.............................
Old 03-07-2008, 09:20 AM   #13
MatthewLFD
My Ride: 550i 6spd + Corvette
Have any of you jacked up your car and grabbed the driveshaft to see if it has side to side play? I had that noise once anytime a load was put on it in gear. I figured it was the carrier bearing so I bought one and when I went to install it I saw that the two nuts holding the center support up were loose. So I tightened them up and was good to go. I've still got a new carrier bearing I'd sell ya if thats your problem.
MatthewLFD is offline   Reply With Quote
Old 03-07-2008, 10:16 AM   #14
FiShDoG323i
Question
I will have to check that out, sounds possible, but how does or how did the center support come loose ? just curious thnaks.
Old 03-07-2008, 10:48 AM   #15
MatthewLFD
I had a shop take the tranny off and I guess they forgot to tighten those two bolts...that or they weren't torqued really tight and just vibrated loose.
Old 03-07-2008, 11:27 AM   #16
FiShDoG323i
i will stll check it out, hopefully today since i have no cars in my service bay at the moment but that could change after lunch. i'll let you know what i find.
Old 03-07-2008, 03:57 PM   #17
FiShDoG323i
Question
just checked driveshaft on lift at work with another tech. everything seems normal, center bearing, flex disc, u-joints, the only play int the drive line is what i think to be normal gear back-lash not much but a little. other tech said drive-line feels very good, so now i wonder what to do next, i have been told that a transmission reflash or firmware upgrade may fix this. is this true, has anyone heard of this or had it done? please let me know. thanks!
Old 03-07-2008, 04:09 PM   #18
black323i
My Ride: 323i
as far as i know, the software upgrade is for autos. not sure if urs is or not.
btw, does the rear knock when ur coming to a stop?
Old 03-07-2008, 04:28 PM   #19
FiShDoG323i
Question
yes it is auto and when coming to a stop it makes a clunk-thud type noise when the trans shifts down
Old 02-16-2011, 07:35 PM   #20
BeeEmmDoubleU
My Ride: 99 323i
bringing this thread back to life.
i feel the thump as my auto tranny downshifts ; bushings bad or DIFF is qoinq ? need help asap
-99 323i -M6 Wheels -3000W of music -Matte Grill
-35% Tint all around -50% on windshield
Plans: -Red/Clear tails -M3 front bumper -Full respray Alpine White -Black Roof
BeeEmmDoubleU is offline   Reply With Quote
