Old 02-16-2011, 09:06 PM   #21
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Originally Posted by BeeEmmDoubleU View Post
bringing this thread back to life.
i feel the thump as my auto tranny downshifts ; bushings bad or DIFF is qoinq ? need help asap
My rear diff bushing was bad and I had a noticeable clunk into 1st or Reverse in my manual...and I think your clunk might be something similar...hope so...much easier than diff or trans!
I suppose it could also be csb...I did that too, along with guibo. The bushing is visible and you might notice it squished or noticeable bad otherwise.
And, of course, inspect things...there are other things that clunk...like subframe issues...but no need to go there quite yet...not before an inspection anyway!
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 02-16-2011, 09:33 PM   #22
rfier
My Ride: 99 BMW 323i E46
i had that too ended up with a new rear diff bushing.... but get your subframe checked
Graphic Designer: Will do photo edits for free (when i have time) shoot me a PM
BMW 99 323i e46: EE Halo Lights, Custom Pipe Style CAI, White Corner & Side Lights, Flat Black Grilles, Short Shift Kit, Aluminum Pedals
Coming Soon: H&R Sport Cup Kit, M3 Front Bumper, MTech Rear Bumper, GTR Style Hood, E-bay Headers, Rear LEDs, 18s, Magnaflow Muffler, BMW E46 330i M54 3.0L Engine
rfier is offline   Reply With Quote
Old 04-01-2013, 11:45 AM   #23
03BIMMERM3
My Ride: 2003 BMW M3
Not sure if you already checked, but I had a loud metal clank in my rear as well, check ur rear springs/shocks, might be broken or blown
Sent from my myTouch_4G_Slide using Bimmer App
03BIMMERM3 is offline   Reply With Quote
Old 04-01-2013, 01:08 PM   #24
SilverMayn
My Ride: ZHP,325i,e36 m3
Don't want to scare you but since you drive a 323/328 you prolly have the same issue I did. My whole rear end was ripping apart from the chassis....good thing I can weld...
all 4 mounting points for the rear subrame were tearing the sheet metal..
Hair line crank under rear seat
This Mounting point fell completely out when i jacked the car up
SilverMayn is offline   Reply With Quote
Old 06-26-2015, 03:38 AM   #25
CBDKustumz
My Ride: 1999 BMW E46 328i
I have BAD vibration at center support bearing if I accelerate hard, or between 30-35mph. *Automatic Trans by the way* After just replacing both axles and wheel bearing the clunking has returned when I shift into gears and also while I'm coming to a stop as Trans downshifts I usually hear clunk. You can easily hear the Clunk(s) when standing outside by car. I'm running out of things to replace or check! I've Replaced Center support bearing/Guibo/both motor mounts/both transmission mounts/both rear wheel bearings/Main Rear Diff Bushing/Both rear drive axles/Flushed Rear diff fluid/ball joints seem good/I don't think drive shaft is bent or unbalanced because you can only really feel it at 30-35mph and not the entire time. it runs great on highway! Problem has existed for 6 months. I was forced onto a curb going about 30-40 by a driver that pulled out in front of me. It deployed my driver windshield pillar and door airbag. the next day i left on a 5k mile trip.(NOT A SINGLE ISSUE), drove like i always did. about 200 miles from home took of fast from a red light and right about 30mph it started. Ive Been OVER and OVER the car. Ive had it on my lift and apart at least 15 times. nothing seems bent or damaged from it. I don't know why it exists. about a month after it started the Center Support finally tore. replaced CSB/Motor&Trans mounts/Guibo. Problem was not so bad about another month into it i replaced both rear wheel bearings/both axles/Main rear diff bushing and it has been a lot better since. but it still exist if you try to accelerate quickly and clunking has become bad since last attempt to fix it..
CBDKustumz is offline   Reply With Quote
Old 06-26-2015, 09:03 AM   #26
dmax
dmax's Avatar
If you did your flex disk yourself...or even if not...not my comments on recent 'flex disk' thread about how critical the mounting of that properly is.
See me in June!
dmax on Facebook
Mangofy your E46!
