Old 09-12-2006, 09:25 AM   #1
zulu4
My Ride: Z4
fitting an E46 infinitas SK1 kit onto a Z4
hi guys,
any idea if its possible to fit the infinitas ASA SK1 from an e46 onto a Z4?
i recall a post about this in the past but i tried searching and couldn't dig up anything.
many thanks
zulu4 is offline   Reply With Quote
Old 09-12-2006, 12:30 PM   #2
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
I have seen two Z4s with that kit. IIRC, the location of the MAF/intake is slightly differerent from the E46s. The rest of the hardware should be pretty straight forward. If you want a thorough confirmation, contact Technik directly.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 09-12-2006, 12:54 PM   #3
clean-m-tech330
My Ride: Technik 330ci ZHP
Send a message via AIM to clean-m-tech330
exactly, I'd be curious about the brackets, but I'm sure it's possible, just give technik a call or email them and you'll be fine
'00 Honda Civic Si- B18c5 210whp- Sold-
'05 BMW 330Ci ZHP- Technik's ZHP - Sold
'06 Acura RSX-S- Sold
'07 Subaru Satin White Pearl STI - Garage Queen
'11 Honda Civic Si Sedan - Daily
clean-m-tech330 is offline   Reply With Quote
Old 09-12-2006, 02:01 PM   #4
zulu4
My Ride: Z4
thanks guys! i've been contacting samir quite a bit recently so i thought i'd better give him a break from my incessant questioning.
maybe just one more question won't hurt....
i remember he did mention that unlike the E46, the Z4 does not have an OE fuel pressure regulator. i'm sure this can be corrected by adding a rising rate fuel pressure regulator right?
Old 09-13-2006, 02:04 PM   #5
wilman2772
My Ride: E60
Oh....I was about to say the main charger bracket of the E46 might not fit Z4 cos Z4 have variable steering.........
kekeke
Samir will tell you what you need to do a full conversion from E46 to Z4 for SK1...
Nice to see u here Louis!!
Bilstein PSS9 / 20" MAYA DLS Black / Toyo T1-R / Eisenmann Race / H&R Sways / Brembo BBK
wilman2772 is offline   Reply With Quote
