Old 05-03-2002, 11:28 AM   #1
ism409
>:P
My Ride: 2000 328i
Send a message via AIM to ism409 Send a message via Yahoo to ism409
Will 330 rotors fit on a 328?
Wanted to put a set of thes on.. Will they fit?
Tit Silver 2000 328i. sp/pp/5spd.
oem clears, DIY silvervisions, hamann shadow grille, gen 2 DAE's, silver headlight trim, UUC RKIII..more to come.
ism409 is offline   Reply With Quote
Old 05-03-2002, 12:01 PM   #2
mfino
I give up.........
My Ride: 00 323i SP-P blk/blk
I don't think so. I think you will have to replace the brake carriers? Not sure though.
ECIS Intake | Shark Injector | Scorpion Exhaust | PG2 style rims, YOKOHAMA AVS ES100 235/40/18 | M3 Lip Spoiler | OEM Clears | Hamann Eyelids | M-Technik Front | M-Technik Sides | M-Aero Rear | 50% Tint | M3 Dead Pedal | MOMO Aluminum Pedals | UUC Gauges |Titanium Shadow Painted Trim
mfino is offline   Reply With Quote
Old 05-03-2002, 12:14 PM   #3
Dave
Moderator
Dave's Avatar
My Ride: 323,330,M3,M3,M3
yes.
as long as you've got the 17" rims...
Perhaps you think multi-million dollar ad campaigns make a beer taste better. Perhaps you're mouthing your words as you read this.
Dave is offline   Reply With Quote
Old 05-03-2002, 01:07 PM   #4
topazmania
Ogler of Women and Mods
My Ride: '01 M3 cab, '90 325i
The rotors will fit. However, you will need to replace the brake carrier with the ones from the 330. These cost ~$100 each.
Also, the rear calipers of all non-M e46's are the same. However, the front caliper of the 330 differs from the rest. Now, if someone knows if the front brake pads for the 330 are a different size than the 325, then the calipers also need to be replaced ($250 each).
topazmania is offline   Reply With Quote
Old 05-03-2002, 01:37 PM   #5
Full Time Hit Man
Banned
My Ride: E46
Send a message via AIM to Full Time Hit Man
I don't think the rotor will fit, cause the 330 caliper is bigger.
Full Time Hit Man is offline   Reply With Quote
Old 05-03-2002, 01:41 PM   #6
topazmania
The rotor will fit, provided you replace the items discussed above.
