Closed Thread
Old 09-13-2006, 03:48 PM   #1
bmw3series
Banned
My Ride: ///M trizzle
P1411 Service engine soon light code...someone help
Hey guys car is giving this error code its p1411, its got says its the manu. auxilary something. I dont recall, but anyone with a bentley manual help me out
btw car is not idlin right at all.
bmw3series is offline
Old 09-13-2006, 05:13 PM   #2
Bodo61
My Ride: 323i
P1411 (M56 eng) Secondary Air Pump No Activity Detected. Sounds like your secondary air injection pump. There's a fuse check that first. There's a relay behind the glove box. The Secondary Air Injection Pump is the round canister device to the back right of your windshield wiper fluid reservoir. The Secondary Air Injection Pump valve sits in front of the pump (has hose from pump to valve).
Bodo61 is offline
Old 09-13-2006, 07:21 PM   #3
cory58
My Ride: e46 / e30 / F30
I got a check engine light at about 58k miles and the Peake code told me it was the secondary air system. I replaced the pump and valve described above and it fixed the problem. Bav Auto told me this is a common failure on the e46. The parts were approx $375, so you may want to just try replacing the valve first before you spring for the pump. I also learned that the small tubing (somewhare around 5-6mm) that connects to the valve gets brittle and cracks when you disturb it, so either have some handy when you start the project, or know where you can get some quick. Needless to say, it was almost impossible to find the tubing in Memphis, TN - cus only them dang for'n cars use metrics.
I think I also had to get a gasket or 2 for the pump and valve. This is a very easy diy.
cory58 is offline
Old 09-13-2006, 08:07 PM   #4
bmw3series
Banned
bump for anymore info/experiences. Would this cause the car to mis fire? Im getting a misfire single also p0304
Old 09-13-2006, 09:18 PM   #5
Bodo61
My Ride: 323i
I beleive this all is connect to the fuel injection system so... One thing you may try, sometime back I had was trying to detect where a noise was coming from and recall listening to the seconday air pump (mechanics stethoscope). If you hear a unique sound (compared to surrounding sounds) then I would say it is working, culprit valve? . If no sound then?? Fuse, relay, pump.
Bodo61 is offline
Old 09-13-2006, 09:28 PM   #6
bmw3series
Banned
i do hear wierd noises...
Old 09-14-2006, 01:56 AM   #7
TypeRvirus
My Ride: 04|325CI|ALPINEWHITE
Send a message via AIM to TypeRvirus Send a message via Yahoo to TypeRvirus
my car is at the dealer right now for the same problem i'll let you know when they fix it.. first i get the p0411 then p1411... i notice when i unhook the hose from the pump going to the motor it gives me the p1411.. we'll c what the technician say..
anyway did you know it's cover under the federal emission law for 8 years, 80k miles...
|BMW|04|325CI|ALPINEWHITE|30%TINT|ECIS|INTAKE|
TypeRvirus is offline
Old 09-14-2006, 04:50 PM   #8
bmw3series
Banned
bump ..anyone?
Old 09-14-2006, 09:39 PM   #9
TypeRvirus
Ok, Here's what i got from the dealer.. for code P1411.. btw it's not cover under emission... it's in your book..
They replaced the Vavle...
11727553064 - vavle list cost 138.45 got it for 89.95
11727514960 - Gasket list cost 6.50
Old 09-01-2007, 03:34 PM   #10
mechanic_101
My Ride: 2005 325I
where is the fuse for this? I wanted to check it first before jumping to others. Does the pump on all the time when engine running? There is another black device (sits next to the pump, size of the apple) hooked up to the pump, what is that?
Thanks,
mechanic_101 is offline
Closed Thread
