Old 09-14-2006, 02:34 PM   #1
12CMiM3
My Ride: 2003 CB M3
need help asap with led taillights...
hey guys,
i took my car in for the emissions recall. and asked them to reflash the lcm while it was there (did the led taillight retrofit). they just called and said the led taillights were flashing and that the connection is bad. and that they can't do anything about it cuz it's not oem.
thing is, i got the part from a bmw dealer. i heard the led's flash in sequence when not reflashed. i told him this but he says it's the connection and that the install wasn't done properly. but this is plug-n-play, isn't it?
what should i tell them. or instruct them.
help, anyone????
______________________________________________
performance: VFE Stage 2; Eisenmann Race 83mm exhaust; KW V2; Turner camber plates; RE RSMs; UUC Evo3 SSK w/DSSR
exterior: Radenergie R10s (19x8.5f, 19x10r); V-CSL front bumper; LED DDEs; ACS roof spoiler; V-CSL rear diffuser; LED taillight retrofit
interior: IconTV with DVD player; hardwired V1 with StealthOne; reverse camera
12CMiM3 is offline   Reply With Quote
Old 09-14-2006, 03:29 PM   #2
12CMiM3
My Ride: 2003 CB M3
anyone with any advice???
want to tell him before he finishes up.
please~~~
Old 09-14-2006, 03:35 PM   #3
ca1242
My Ride: 2003 330i
Yes, they should be plug and play. Are you sure these OEM lights?
Old 09-14-2006, 03:38 PM   #4
12CMiM3
My Ride: 2003 CB M3
thanks!
i'm pretty sure they are...got em from unique design who sed they were oem. the shipment came from a bmw dealership, so i can only assume they are.
it seems like since the leds were flashing at the beginning that the SA thinks its a connection problem.
Old 09-14-2006, 04:27 PM   #5
Alex323Ci
My Ride: M3 & 323Ci (sold)
The flashing/strobing is from the Check System of the car making sure you don't have any bulbs out. Did they reflash your car to accept LEDs? As long as you have the later style LCM it should be able to be reflashed to accept the LEDs if these are OEM LEDs. Otherwise the early LCM can't be reflashed.
I don't see how you could have connected them wrong. Either they will plug in with the adapter or they won't. I can't see the Tech not just pushing the connectings in further had they actually not been connected right(which would be hard to not plug in all the way).
Old 09-14-2006, 04:45 PM   #6
ca1242
My Ride: 2003 330i
^^ What he said for the strobing at the beginning. Have them check to make sure they flashed it. If not, you can always build a "filter" using some resistors and capacitors.
Old 09-14-2006, 08:17 PM   #7
12CMiM3
My Ride: 2003 CB M3
ok so here's what happened...
i go to the dealer and tell him i don't understand what the problem is. i doubt that the connection is bad b/c it's basically plug n play. he says, well, not really. not really?!? you install it and plug the wires in...that's pretty much plug and play to me. anyway, he said the tech adjusted the wires so the lights are out now, but they want guarantee that it won't come back on. also said that it didn't need the reflash.
and i told him that i got the parts from another dealer so that i'm fairly certain that they're oem parts.
what do you think? kinda seemed like maybe he was wrong so he just said that they "worked with the wires" to make it seem like they did ME a favor or something. who knows? maybe they were right. sounds a little fishy to me though.
any thoughts?
Old 09-15-2006, 12:10 AM   #8
BMWBoiDE
My Ride: 2010 328 M SportVert
If you got BMW tails you should have also gotten the BMW adapter connectors. It is a set of wiring adapters (about 6 inches long each) that connect the old connector from the car to the new connector on the tailight. They are specific to each side of the car and have a label for left and right. You may have put the wrong one on each side. Car after 9/01 don't need a new LCM. Just a reflash of the LCM using the LED tail retrofit path.
BMWBoiDE is offline   Reply With Quote
Old 09-15-2006, 04:36 AM   #9
Alex323Ci
any thoughts?
Sounds to me like they never did the reflash before and are back pedalling. Although you do have the later 2003 LCM, the car is still set-up to check for filament bulbs. I can't see how there is any way that the car wouldn't throw fault codes or lights out when installing the much different LEDs without teaching it/coding it to accept? You just can't throw in LEDs on a car not equipped with LEDS and have it work without dash warning lights triggered. I have not heard of anyone ever doing it by simply plugging in and being done.
Old 09-15-2006, 07:51 AM   #10
ca1242
My Ride: 2003 330i
If they lit up before, they were plugged in already. There is no "partially plugged in" connection. Sounds like they didn't flash it the first time. So it is all well now?
Old 09-15-2006, 08:03 AM   #11
bagher
Account closed.
bagher's Avatar
Send a message via AIM to bagher
My M3 is 2002 (build date 9/01) do I need a new LCM or can they just reflash mine?
bagher is offline   Reply With Quote
Old 09-15-2006, 09:27 AM   #12
12CMiM3
My Ride: 2003 CB M3
yup, used the new wires that came with the led "kit".
that's what i think. i think they said it can't be done b/c of blah blah blah. i told them it should be able to be done. they prolly tried it and it worked and didn't want to look like they didn't know what they were doing so they told me it didn't need to be reflashed, but we "worked with the wires" for you and it worked. at least that's the feeling i got.
i know. that's what i was saying. it's plug n play. it's either in or it isn't. and he responds to it with a "not really". ah well. but it seems to be working now. granted, it's only been a day. and by "working" i mean the warning lights haven't showed up.
what's weird is that this was supposed to be a pretty reputable dealer/service dept. i figured they'd know their stuff.
i think you need the LCM, but i'm not definite. i'm not sure exactly when the cut off is. i thought it was at 2002...so 2003+ you're good to go.
nice car, by the way.
Old 09-15-2006, 09:30 AM   #13
bagher
Account closed.
bagher's Avatar
thanks, does anyone have a part # for the updated LCM? Also if you buy an updated LCM does it still need to be reflashed?
Old 09-15-2006, 09:47 AM   #14
ca1242
My Ride: 2003 330i
THey screwed up, came up with BS story to cover it up. Everybody makes mistakes. I just can't understand why people can't just admit it and take care of things.
Old 09-16-2006, 11:00 PM   #15
mfnatic
My Ride: m3
Send a message via AIM to mfnatic
plug n play isnt oem. the oem ones you need to buy a cable set, bulb carrier, bulb socket, two bulb holders, and two covering. i am in the process of installing my led taillights. good luck
mfnatic is offline   Reply With Quote
Old 09-17-2006, 02:29 AM   #16
Alex323Ci
where did you get that info? You need the LED lamps, the adapter cable set, the bulb carriers, and maybe the side coverings(although the original ones will work also). I've had mine on for almost two years now, installed them myself.
Old 09-17-2006, 11:39 PM   #17
12CMiM3
My Ride: 2003 CB M3
but the cable set is just plugged in and then played....is what i meant.
