Old 09-11-2006, 12:23 AM   #1
v3man
My Ride: TBM 2001 330Ci
Send a message via AIM to v3man
xenon bulb out?
so installed my dde's a little less than a week ago... and tonight, after i filled up gas.... i realized that my right oem projector [xenon hid] was out.... i was wondering if i messed up wiring somehow or if these 2 have any relation to each other? or if it just went out? maybe i could do something so the light turns back on? haha.. if so.. what can i do? if not.. where can i get the bulbs if they are bulbs.. i dont know much about xenons so i dont know if they have bulbs or what.. but can anyone give me some insight on what maybe happened and/or solutions to my current dilemma? thanks..
v3man is offline   Reply With Quote
Old 09-11-2006, 02:56 AM   #2
v3man
bumpity bumpity??
Old 09-11-2006, 03:53 AM   #3
Mike@Modbargains
ModBargains CEO
Mike@Modbargains's Avatar
My Ride: 2008 BMW 135i
Bulbs do burn out from time to time, but you might want to check the connection first just to be sure that it's not a simple fix. We sell replacement 6000k and 8000k xenon headlight bulbs here if you need a replacement pair and want to change the color to match up with your halos :
http://www.modbargains.com/product.a...e46%2Dlight001
Authorized Dealer of: Forgestar Wheels l KW Suspension l VMR Wheels l Miro Wheels
Hours: Monday - Friday 8am - 7pm, Saturday 8am - 5pm (PST)
We Specialize In: BMW Parts | BMW Rims | BMW Wheels | BMW Exhaust
Mike@Modbargains is offline   Reply With Quote
Old 09-11-2006, 03:28 PM   #4
v3man
is there a common problem associated with this? cause you said "make sure it's not a simple fix".. what should i look for? and what common problems could there be? if i pull out the bulb how can i tell if it's blown or not? i dont know much about the assembly of these things, nor do i know much about them.. any input guys? thanks!
Old 09-11-2006, 04:31 PM   #5
Mike@Modbargains
ModBargains CEO
Well basically what I'm referring to is make sure you didnt knock the bulb loose or disconnect any wires while you were doing your angel eyes installation. There aren't any problems that normally occur with xenon bulbs that I know of.
Old 09-11-2006, 05:13 PM   #6
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
A xenon headlight failure could be attributed to a multitude of problems. The best thing to do is narrow it down to either the bulb or ballast. Swap the bulbs from one side to the other to see if the problem switches sides. If so your bulb is out. If not, you may have a bad ballast or even a connections issue.
Old 09-11-2006, 05:52 PM   #7
v3man
how can i tell if the bulb is out by looking at it.. or can i? and would anyone happen to have pictures of the different colors of the bulb?
Old 09-15-2006, 07:53 PM   #8
jmueller
My Ride: 2001 330ci
what if the headlight is flickering (like its trying to start, but cant..) what would you do
jmueller is offline   Reply With Quote
Old 09-15-2006, 07:55 PM   #9
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
sounds like a bad ballast...
Timeless Motor Group
