Old 09-14-2006, 11:12 PM   #1
jstar41
My Ride: TopazE46|MontegoE92
Prolume HID bulb acting up.. (Umnitza)??
hello all.. it has been a while since i posted.. anyways.. my right Prolumen bulb is acting up.. well i'm not sure if it's the bulb or the ballast.. when i turn my fogs ON both bulbs go ON.. about 30 secs later the right bulb goes out.. i thought it was the bulb that died but then I shut the fogs OFF and turned back ON and they both light up again.. about 30 secs later the right one goes out again.. so i do this for a couple of times and then the bulb stays ON.. not sure what's going on.. any ideas??
I bought this kit from Umnitza last year.. anyone know what's the warraty on this kit.. this is a great HID Kit, i just hope it's a quick fix.
thanks!!
JSTAR41
jstar41 is offline   Reply With Quote
Old 09-14-2006, 11:16 PM   #2
PreppyR6
My Ride: shines like justice
Side note, gorgeous car man, I love it
Good luck with the fogs
PreppyR6 is offline   Reply With Quote
Old 09-14-2006, 11:22 PM   #3
jstar41
^^ thanks bro..
_______________
I just read on another thread that the ProLumen kit have a lifetime warranty..
any ideas what it may be before i contact umnitza?
JSTAR41
Old 09-15-2006, 01:57 AM   #4
n3985
My Ride: E92 soon?
Your symptoms sound like the HID bulb is dying, the easiest way to check is to swap the bulbs, and see. IF the left side bulb is on the right when tested, and the samething happens, then you know it's the ballast. Good luck
n3985 is offline   Reply With Quote
Old 09-19-2006, 02:32 PM   #5
bave46rider
My Ride: e46
thanks!!
They supposedly have lifetime warranty, so whether it's your ballast or bulb or igniter that's bad, the vendor should replace it for you for free. Give them a call.
bave46rider is offline   Reply With Quote
Old 09-19-2006, 02:36 PM   #6
Tutankhamon
My Ride: 2017 M2, 2002 330ci
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
As another has stated, simply swap the bulbs and see if these symptoms follow the bulb or remain with the ballast.
Tutankhamon is offline   Reply With Quote
Old 09-19-2006, 07:28 PM   #7
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Yep, swap the bulbs independently, then the ballasts, then the igniters to determine what exactly is at fault.
Old 10-11-2006, 07:23 PM   #8
jstar41
thanks Umnitza.. I did not even have to contact them.. they contacted me once i posted.. excellent customer service and warranty!!
JSTAR41
