Old 09-19-2006, 08:36 PM   #21
donjuan45i
My Ride: e.quart.seis
maybe you smelled that burning smell like trippinbilly did, and the smoke you saw was from a car infront of you?
donjuan45i is offline   Reply With Quote
Old 09-19-2006, 11:21 PM   #22
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
Its typical for new electronics of that sort to break in a bit the first time they get hot. Oil and other imperfections and contaminations from the manufacturing process will burn off a bit and then they will work fine.
I wouldn't be too worried about it.
there aren't really any unpainted pieces of metal you could mount it to since all the metal in that rea is steel.
Tyler@UniqueDesign is offline   Reply With Quote
Old 09-20-2006, 12:28 AM   #23
Tutankhamon
My Ride: 2017 M2
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
Well guys, thank you all for the help. I was convinced that the problem went away but today the smoke returned. I was able to find out the source of it and it was not my LED blinkers at all. I wish it was
The white smoke seems to be coming from the side of the engine closest to the firewall. I've done a search and this seems to be a symptom of a blown valve cover gasket
Time to start another thread
In any case, thanks JL for the blinkers, they are working great.
Tutankhamon is offline   Reply With Quote
Old 09-20-2006, 12:34 AM   #24
Tyler@UniqueDesign
Car Junky
Look for leaking oil, valve cover gasket isn't that hard or expensive to change.
Old 09-20-2006, 12:50 AM   #25
Tutankhamon
My Ride: 2017 M2
Thanks for the tip, I will look for any type of oil leak, I pray that it's that gasket then if it's not so hard or expensive to change.
I started a new thread in the general section so if you have any further insight, by all means any help is appreciated
