Old 09-18-2006, 09:02 AM   #1
TrippinBillyFL
I might as well be dreaming
TrippinBillyFL's Avatar
My Ride: 2004 330Ci
Send a message via AIM to TrippinBillyFL
angel eye wiring connections
I am one step away from completing my Predator Chromium angel eye install and have a problem. When connecting the power/ground wires from the relay to the ignitors, the connectors do not match. The wires coming from the relay have the connectors shown here:
http://www.fastm.com/m3/angeleyes/angeleyes04.jpg
The problem is that the ignitors do not have the matching connectors shown here:
http://www.fastm.com/m3/angeleyes/angeleyes03.jpg
Instead, they have a very small (1mm wide by 1cm long) single metal plug on both wires. I have no problem buying the correct connectors and attaching them to the ignitors, but I have seen lots of threads and comments by sponsors that say if you mess with the wiring then the warranty is void.
So my question is... and hopefully some sponsors (Mike@Mod,Nick@JLevi) will have some insite... should I replace the connectors on the ignitors to match the connectors on the relay wires? Will this void my warranty?
TrippinBillyFL is offline   Reply With Quote
Old 09-18-2006, 09:07 AM   #2
Tutankhamon
My Ride: 2017 M2, 2002 330ci
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
You can just cut off all the connectors, connect the wires with solder and shrink wrap.
Tutankhamon is offline   Reply With Quote
Old 09-18-2006, 12:34 PM   #3
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
I'd check with Matt before doing that - its fine for those kits, but don't want to void the warranty or anything.
Tyler@UniqueDesign is offline   Reply With Quote
Old 09-18-2006, 01:25 PM   #4
Tutankhamon
good call
Old 09-18-2006, 03:52 PM   #5
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
My Ride: Vorsteiner 335i
Send a message via AIM to Jlevi SW
The 04 ballasts unfortunately don't have the bullett connectors on there, You should push them into the bullett connector on the harness and squeeze tight with a pliars to lock it together, and then put the sheath over. It also doesn't hurt to use a shrink tube or bit of electrical tape to prevent contact with the chassis!
JL
Jlevi SW is offline   Reply With Quote
Old 09-18-2006, 03:59 PM   #6
TrippinBillyFL
My Ride: 2004 330Ci
thanks for the replies! why isn't anything ever made correctly for the 04 coupes!!! damn it!!! oh well. looks like i'm going home to do some wiring. cheers!
