Old 09-19-2006, 07:36 PM   #1
rchaseio
My Ride: 2005 325i
Non-Adaptive Xenons?
I bought a 2005 325i a couple of weeks ago. Well, I finally found out what options I have. It lists xenons at $700. Are these adaptive or no? They don't seem to swivel left and right. But its my wife's car and I never drive it, so I can only look at it when she pulls away from the driveway.
rchaseio is offline   Reply With Quote
Old 09-19-2006, 08:26 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
They are not adaptive, you have bixenons. The adaptives were only available on facelift coupes.
Old 09-19-2006, 09:13 PM   #3
rchaseio
My Ride: 2005 325i
Thanks, Nick. BTW, what is the difference between xenon and bi-xenon?
Old 09-19-2006, 09:25 PM   #4
donjuan45i
My Ride: e.quart.seis
with single xenon (xenon) your car still uses halogens as the highbeams (99-01 e46s), and with bi-xenons your car uses the xenons as both high and low beam functions(although halogen is still used as flash to pass), I think the bi-xenons are supposed to have better output as a highbeam function versus xenon+halogen.
all xenons have a cutoff shield, behind the projector, that controls (restricts) where the light is spread (to not blind oncoming/and neighboring drivers) With bixenons, when you select highbeams, this cutoff shield is pulled away, releasing unrestricted xenon light.
There are also projector differences, the single xenons use a 2.5" projector while bi-xenons have a 3" projector. And there cutoff is different, most voting that the single xenon has a better cutoff. But the ouput of the bi-xenon projector I think has slightly better (not very noticeable) output.
donjuan45i is offline   Reply With Quote
Old 09-19-2006, 10:00 PM   #5
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
In a nutshell
Although in terms of low beam output, both the bixenon and regular xenon are almost exactly the same. Bixenons do have a bit higher high beam light output, however.
