Old 09-19-2006, 09:15 PM   #1
mattyd
My Ride: 03 330ci
Do i need resistors?
I am about to order Led turn signals for me pre-facelift 03 330ci. Do i need resistors or not? i dont even know what they are
mattyd is offline   Reply With Quote
Old 09-19-2006, 10:02 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
You do need resistors. Resistors prevent the bulb out warning on the dash caused by the lower power draw of the new LED turn signals. Your ECU signals a bulb out when there is a change in resistance along the circuit. Since LEDs run more efficiently than halogens, they draw less power and the ECU thinks the bulb is out. The resistors eliminate this issue by putting a little extra load on the system to make the overall draw the same as stock.
