Old 09-19-2006, 11:48 PM   #1
v3man
My Ride: TBM 2001 330Ci
Send a message via AIM to v3man
all halos out!! HELPP!!!!! please!
so i recently installed my dde's.. and i for a while they had no problem.. but today i noticed one was REALLLLY dim (pretty much off) so i checked it out.. and i noticed that the black thing that has like. a chip and wires coming out of it.. the thing you're supposed to plant somewhere in your engine bay with the double sided tape.... i guess it got really hot and the top part with the chips and wires fell down.... and it was stuck down.. so i started pulling it up a bit and the halo that was out before, turned on... and then i finally got it completely unstuck and then i heard a click.. and ALL HALOS WENT OUT!!!... help!!!! what could be wrong with it?? if it's all blown should i tell my vendor? im completely lost in what to do
v3man is offline   Reply With Quote
Old 09-20-2006, 12:30 AM   #2
islanq
My Ride: An E46 like you...
Send a message via AIM to islanq
Yeah dude, I mean it's unrealistic to think those (the ballast) can't withstand and heat but direct engine heat is probably a bit much for them. What did you secure the ballast down with? Double sided tape I assume? In any case, the double sided tape heats up and won't hold after a while. If you are using tape it's a good idea to plant them in a spot out of direct heat.
islanq is offline   Reply With Quote
Old 09-20-2006, 12:53 AM   #3
n3985
My Ride: E92 soon?
Double check all the connections are tight and check the fuse.
n3985 is offline   Reply With Quote
Old 09-20-2006, 01:15 AM   #4
v3man
what should i look for in the fuse?
Old 09-20-2006, 01:17 AM   #5
e36 emthree
My Ride: e46 TiAg 330ci
Send a message via AIM to e36 emthree
if the metal pieces are connected inside the fuse or not. If they are broken and not touching then the fuse is bad.
e36 emthree is offline   Reply With Quote
Old 09-20-2006, 06:45 PM   #6
v3man
ok.. so i replaced the fuse.. and the fuse that i replaced it with blew right away.... uh.. so what do i do now? haha
Old 09-20-2006, 07:50 PM   #7
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
You have a short in the system. Sounds like it is coming from your busted relay.
Old 09-20-2006, 08:07 PM   #8
v3man
so what can i do to remedy this?
Old 09-21-2006, 11:16 AM   #9
v3man
anybody?
Old 09-21-2006, 12:46 PM   #10
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
You are going to have to find the source of the short first and go from there.
Old 09-21-2006, 06:58 PM   #11
v3man
and how would i go about doing that? i dont know anything about electrical wiring and all that stuff....
Old 09-22-2006, 10:23 AM   #12
n3985
My Ride: E92 soon?
Then I sugggest you find someone who does to diagnose the problem, maybe a regional installer in your area perhaps?
