Old 09-20-2006, 12:07 AM   #1
islanq
My Ride: An E46 like you...
Send a message via AIM to islanq
P46 Head Light Condensation
So I bought some new P46s from Units w/ Pred. Chromiums pre installed. Swapped out my old head lights, put the new ones in, wired up the DDE, everything works perfect. I take my car for a spin about an hour later and get out to admire my work at a near by Albert sons parking lot, when lo and behold, fvcking condensation in the drive side head light.
Now some people are saying SEALING them is a good idea, wtf that makes no sense, u can't have a PERFECTLY sealed head light because there has to either be a side of the boot opened for the wires, or you have to cut a small X incision into the boot.
Ironically the passenger side has a BIGGER X incision then the driver side and there is NO condensation what so ever. I think cutting a bigger incision will do the trick, anyone tried this?
islanq is offline   Reply With Quote
Old 09-20-2006, 12:12 AM   #2
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
I had the same problem, check the seal of the plastic case. Here is a pic of what happened to mine when they were shipped to me, look in the lower right hand corner.
-Gary
DiscoStu is offline   Reply With Quote
Old 09-20-2006, 12:18 AM   #3
islanq
Yeah but even if I make sure the lens is sealed moisture can still get in from the back where the bulb comes in. The rubber shield / boot need an incision or to be left off on the edge. Get what I'm saying? I think the only true way to get rid of it is making it AIR TIGHT, which isn't realistic, or making a big enough incision for the air to properly vent out.
Old 09-20-2006, 12:21 AM   #4
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
If you have condensation then that means water got in some how, whether it was when you were installing them or when you went for a drive. I don't think the headlight being air tight has anything to do with it. I know mine aren't and they never fog up, not even after driving in pouring rain.
-Gary
Old 09-20-2006, 12:27 AM   #5
islanq
Yeah, I will try making a bigger area for air to travel through the boot, hopefully this will clear it up. I have been digging around on the other forums (non bmw just head light condensation threads in general) and everyone is saying either air tight or drill holes. In my case i'm lucky enough to have that rubber boot so I don't have to drill
Old 09-20-2006, 01:02 AM   #6
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Are you sure that the rubber boot on the back is 100% secure. You can run the wires through the top of the boot and still make a perfect seal.
Old 09-20-2006, 01:45 AM   #7
islanq
Yeah it was on pretty good, I doubt i can run all 4 wires (2 for bulb, 2 for DDE) and get a good seal (bulb wires are pretty thick). I'm just going to make a bigger incision tomorrow, if that doesn't work i'll look into the completely sealed options.
PS, this makes me laugh because on my halogen housing I ran the DDE wires out of the back of the light and it was NO WHERE NEAR a perfect seal, 2 months, not on hint of fogging...
Old 09-20-2006, 02:24 AM   #8
PhillyKatBMW
My Ride: BMW
try opening it up...drying out all the condensation...then stashing a couple of silica gel desiccants between the trim and the headlight casing...its worked for me and I had persistent condensation on my passenger's side headlight that was driving me totally nuts...
-Chevalier Mal Fet-
PhillyKatBMW is offline   Reply With Quote
Old 09-20-2006, 12:32 PM   #9
BMW Loe
My Ride: is dirty
I've 'X' scored some of my rubber boots to run wires through as well but I haven't had any issues with condensation to date.
E92 335i 6spd
BMS JB4 stg 3, BMS DCI, CM methanol injection
04 M3 sold
03 330Ci sold
BMW Loe is offline   Reply With Quote
Old 09-20-2006, 04:58 PM   #10
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
That is a really good idea that I'm surprised noone had come up with earlier - silica packats, hell, even rice would work
Tyler@UniqueDesign is offline   Reply With Quote
Old 09-23-2006, 05:26 PM   #11
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
My Ride: Vorsteiner 335i
Send a message via AIM to Jlevi SW
Just as I suspected. Your problem is circled in red.
Straighten out that tab. You're trying to close your headlights with a piece of plastic in the way and it's letting condensation in. Big problem. Happens a lot if you aren't careful!
That should solve it. Don't bother with silicone.
JL
Jlevi SW is offline   Reply With Quote
Old 09-24-2006, 01:59 AM   #12
Tyler@UniqueDesign
Car Junky
JL
....That was DiscoStu's picture - and he identified the problem. The OP was islanq.
