Old 09-24-2006, 02:34 AM   #1
mfanatic325
My Ride: '01 911 Turbo
Solution(s) to: Opening Headlight-Housing Problem?
I want to either
1. swap out my facelift coupe's front amber inserts for clears (can get clears from a local)
OR
2. just take out the amber inserts and drive without them...(got front LED turn signal bulbs)
my dilemma is that I have LaminX film (costed me $40+) on my headlights, and I don't think I can bake them (right?)...and I don't have access to-or know how to operate-a heat gun does anyone have a solution for me?
mfanatic325 is online now   Reply With Quote
Old 09-24-2006, 09:13 AM   #2
ca1242
My Ride: 2003 330i
Check the specs of the film. How high of a temperature can it withstand?
Old 09-24-2006, 10:58 AM   #3
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
DO NOT USE A HEAT GUN.
You can use a blow dryer though.....the real risk with the heat gun is that you will overheat the headlight. Even with the blow dryer you want to be careful and get a lot of movement - but thats what the original DIY's listed as a method for getting the headlights open, baking is just faster/more consistant heating.
Tyler@UniqueDesign is offline   Reply With Quote
Old 09-24-2006, 01:29 PM   #4
mfanatic325
if I use a blowdryer, about how long do I need to heat the glue for (assuming I'm moving the blower around as consistent as I can)?
Old 09-24-2006, 02:53 PM   #5
Tyler@UniqueDesign
Car Junky
I couldn't tell you - never actually done that myself, but the installation instructions for the very DDE's you bought say to use a blow dryer. The site is ona taiwanese server so I rehosted the image, kindof hard to read but here you go:
