Old 09-24-2006, 01:27 PM   #1
KATO
My Ride: Blk 2000 328i 5speed
What determins max HP
What is the maximum horsepower a super charger can produce with 328? On the Active Autowerke's
Web site it list 257 rear wheel horsepower at 8 psi. Can the psi be increased to increase the horsepower? For example, they list the 330 at 277hp@ 8psi. Can a 328ís psi be increased to match the hp of the 330?
What is the limiting factor in determining hp on a stock engine?
Engine size
Transmission
Boost
KATO is offline   Reply With Quote
Old 09-24-2006, 02:23 PM   #2
AS007
My Ride: 328Ci
Send a message via AIM to AS007
You can raise the boost, but there is no software for anything higher than 10.5 psi I believe.. And going much higher would require you to lower the compression via pistions. You could raise the boost and then do a ported cylinder head, headers, full exhaust, and some cams and you would be well over a 330ci w/ just supercharger.
AS007 is offline   Reply With Quote
Old 09-24-2006, 03:16 PM   #3
GodSendsDeath
My Ride: 2008 350z 6-speed!!!
I dont want to sound mean, but "There is no replacment for displacment". You can boost all you like, but how much can that block and motor take is the question. Good luck with everythin.
GodSendsDeath is offline   Reply With Quote
Old 09-25-2006, 12:02 AM   #4
KATO
Thanks for the info. After doing some research, I found that a 328 could produce in excess of 300 rwhp.
http://forum.e46fanatics.com/showthr...&highlight=328
