Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 09-25-2006, 01:03 PM   #1
Enderson
My Ride: 2004 BMW 325i
Commom problems with your E46
Can everyone post the problems that they have had with their E46 so that we can try to find a pattern of everything that we should expect to have to replace/fix on our 3 series? I am doing a study on the commom issues with the E46's. If you've had no problems (Lucky you!!!), just post "no problems" and how long you've had it.
Thanks,
Ok, I'll start:
-Passanger's side mirror's motor went out at 40k miles on a 2004 325i. Covered by Factory Warranty.
-Weird noise coming from front right wheel (haven't figured out what it is yet)
2004 325i
Sports Pkg
Premium Pkg
Xenon
Leather
Enderson is offline   Reply With Quote
Old 09-25-2006, 01:16 PM   #2
mholter
My Ride: 2007 328xi
Smile oh the problems.....
The only problem I've noticed is my handsome car that runs great still sits in the same crappy traffic. And not enough girls have ridden in my car. HA!
04 325 Coupe - 25K miles
mholter is offline   Reply With Quote
Old 09-25-2006, 01:53 PM   #3
Tutankhamon
My Ride: 2017 M2, 2002 330ci
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
Only confirmed problem so far: airbag light is on, might be wiring or something under the passenger seat in my coupe. Error reads out a problem with passenger seat belt tensioner and passenger occupancy sensor... probably a wiring issue.
unconfirmed problem: valve cover gasket
otherwise, problem free.
Tutankhamon is offline   Reply With Quote
Old 09-25-2006, 02:06 PM   #4
Bostonbimmer
My Ride: 2011 328
Send a message via AIM to Bostonbimmer
Problem - Windshield wipers randomly turn on if I hit a bump in the road -
Solution - I turn them off
Bostonbimmer is offline   Reply With Quote
Old 09-25-2006, 02:25 PM   #5
tee51397
My Ride: 330i
Only problems have been window regulators, thermostat and water pump.
tee51397 is offline   Reply With Quote
Old 09-25-2006, 02:27 PM   #6
yoda2
My Ride: 2000 328i, 2002 325i
DSC light on
yoda2 is offline   Reply With Quote
Old 09-25-2006, 02:46 PM   #7
manydubs
My Ride: 1995 BMW M3 Coupe
Window regulators, control arm bushings, sway bar links, strut mounts, rear shock mounts, sun roof shade....
manydubs is offline   Reply With Quote
Old 09-25-2006, 02:59 PM   #8
Christapher05
My Ride: .
Send a message via AIM to Christapher05
Window regulators tend to go out alot, bro/mom had it replaced about 3 weeks ago
Christapher05 is offline   Reply With Quote
Old 09-25-2006, 03:06 PM   #9
Aboyse46
My Ride: 03 325i
Almost hittin 80k on my 330..only problem so far is my sunroof shade..other than that..shes fine...(knock on wood)...
'01 330Ci w/ Navi..SOLD
93 integra DA9. daily driven
03 325i Sports/premium (Totaled 1/24/14)
06 Acura Tl (Current)
Aboyse46 is offline   Reply With Quote
Old 09-25-2006, 03:12 PM   #10
loko-moko
My Ride: 330CI
2002, 330CI, 60k miles
@ 60k - new transmission
@ 47k - new window trim and door seals
@ 48k - new door seals again
@ 50k - new speakers
@ 50k - sunroof leaking (drain tube detached)
@ 55k - new battery
Everything but battery was warranty.
loko-moko is offline   Reply With Quote
Old 09-25-2006, 03:42 PM   #11
MysticBlau330Ci
My Ride: 330Ci '04 & M4 2016
Drivers side door/window trim droop. Both sides replaced under warranty.
Sunshade clips broken. Got most of the broken peices out. Sunroof works perfectly. Will fix clips as a DIY when I'm up to it.
2004 330Ci
MysticBlau330Ci is offline   Reply With Quote
Old 09-25-2006, 04:00 PM   #12
Hrvat
My Ride: 02 Imola Red M3
1st owner:
--> Outside Temp Sensor - common failure
--> Driver's door window regulator - common failure
Me (already replaced)
--> Left and right control arms -$250
--> Front control arm bushings -80
--> Sway bar links -$45
--> Battery -$90
--> Recently, water pump (which required coolant flush), belt tensioners and belts -$150
To be replaced:
--> Driver door brake (the mechanism that holds the door open so it doesn't shut on you) snapped. -$50
--> Exhaust hanger (one just below shifter) burned/rusted off -$15
--> Final Stage Resistor. My fan has it's own mind. -$60
--> Cabin filter -$20
And finally something that's not broken but should be replaced
--> 01 330(c)i suffer from overboosted steering. Steering rack will need to be replaced -$200 from junkyard
**Prices are in US$**
PM ME FOR FREE SAMPLES
Originally Posted by roronoah View Post
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
Old 09-25-2006, 04:01 PM   #13
Hrvat
This would have cost ALOT if I took it to shop but all of the above is DIY and are common failures on E46. I think I should be good to go for a while now!
Old 09-25-2006, 04:46 PM   #14
Enderson
Thanks for the great posts so far guys.
Has anyone had any problems with the ABS or Fuel Lines/Injectors?
Tks again,
2004 325i
Sports Pkg
Premium Pkg
Xenon
Leather
Old 09-25-2006, 05:13 PM   #15
paulney
My Ride: 325i 2001
- two window regulators
- radio (no AM reception. Fixed under warranty)
The rest was maintenance work (belts, bushings, etc).
paulney is offline   Reply With Quote
Old 09-25-2006, 05:18 PM   #16
Hatchd
My Ride: 93 Civic
- A/C not working, most likely final stage resistor
- sun roof shade seems broken, sun roof only closes if I hold the button in. One touch will not close it.
- Odd squeaking noise(almost like a metal squealing) when i get in and out of the car. No idea what it could be.
- Tires keep going flat. Yeah, not a car problem, just pissing me off.
Hatchd is offline   Reply With Quote
Old 09-25-2006, 05:24 PM   #17
guest131
My Ride: Ford Pinto
- Sun roof shade
- Lining on Door (obviously)
- Steering wheel getting locked a bit on tunrs...
guest131 is offline   Reply With Quote
Old 09-25-2006, 05:53 PM   #18
J.D.
My Ride: 2002 330Ci Jet Black
2002 330Ci - currently at 56k miles
Sticky Door Handles - Replaced under warranty
Rubber Door seals - Replaced under warranty
Sticky Gas pedal - Replaced under warranty
CD player skipping - Replaced under warranty[with new MP3-CD player]
Control Arms and Bushings - Replaced under warranty
Belts - Replaced [Not under warranty]
Trunk shocks starting to rust - Replaced under warranty
That's all I can think of for now, nothing serious yet... knock on wood.
J.D. is offline   Reply With Quote
Old 09-25-2006, 05:57 PM   #19
Enderson
Originally Posted by Hatchd View Post
- - Odd squeaking noise(almost like a metal squealing) when i get in and out of the car. No idea what it could be.. .
I'm having the same problem! but everytime I take it to the dealer I can't dupplicate the problem
I don't know what to do either
2004 325i
Sports Pkg
Premium Pkg
Xenon
Leather
Old 09-25-2006, 05:59 PM   #20
Enderson
So far Sunroof shades and window regulators are our top problems...
hum...
2004 325i
Sports Pkg
Premium Pkg
Xenon
Leather
