Old 09-27-2006, 11:34 AM   #1
tdevil
My Ride: 03 325i
Send a message via AIM to tdevil
DDE on/off problem
anyone have a clue on what might be causing this?
unlock - fades on DDEs
start engine - turns off DDE
im guessing, because the footwell lightning went off so did the DDE?
tdevil is offline   Reply With Quote
Old 09-27-2006, 12:35 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
You have a problem with your ECU tap.
Old 09-27-2006, 12:52 PM   #3
tdevil
My Ride: 03 325i
i did the ECU tap first (wo/ doing the footwell tap) and tested it. the DDEs stayed on after the car was shutdown for a few seconds. then i did the footwell tap.
which wire for ECU just so i can recheck.
any other things i should check?
Old 09-27-2006, 02:49 PM   #4
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
The ECU tap should be the pink wire. Make sure you really clamp down on the t-tap that is included.
Old 09-27-2006, 03:34 PM   #5
tdevil
My Ride: 03 325i
ok i will check. thanks!
Old 09-27-2006, 10:55 PM   #6
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
Check a few things:
1. - Is the fuse in blown or incorrectly seated - all the way and actually in the slots, some of the fuse holders are tricky
2. - If you turn the key to the on position, and turn the interior lights on, do the DDE's stay on?
3. - Do you hear/feel a clicking from the relay when you turn the key on (will require an assistant).
If the fuse is blown and a new fuse works - problem solved (same as if its mis-seated)
If the DDE's don't stay on with the interior lights on and the key on, the relay isn't tripping (meaning the ECU tap is good) and there is a problem with the power connection you made (fused wire). Conversly, if the lights stay on (but are off with the interior lights off) you will come to case 3.
If you aren't getting a click from the relay its an issue with the ECU tap, if you are getting a click its an issue with the power wire.
The wiring here isn't very complex - only a certain number of things can actually be wrong, my guess is honestly on something with the power wire.
Tyler@UniqueDesign is offline   Reply With Quote
Old 10-07-2006, 10:00 PM   #7
tdevil
My Ride: 03 325i
Hrmm.
so yea it doesnt seem to the pink wire or unless i didnt tap it correctly.
2004 Facelifted coupe, sport package, bixenon. did not need to bake headlights.
at the moment its like this. I took off the ECU tap altogether. The DDEs fade on and off with the interior lights.
being limited with the provided t-taps i bought new taps from radio shack.
Old 10-07-2006, 10:32 PM   #8
Tyler@UniqueDesign
Car Junky
Not sure what you're talking about here
Did you try the suggestions I gave you?
Old 10-11-2006, 12:20 PM   #9
tdevil
My Ride: 03 325i
sorry just giving out more info about the car. several different DIYs wrote different color wires to tap.
1. which fuse are you talking about? the OEM fusebox in the glovebox or the dde harness one.
2. Yes the DDE's will stay on/off with the interior lights. So basically i think did the footwell tap fine.
3. I will check for this asap. the little box should click right?
using taps for 18-22 guage is correct aye? im using the radioshack onces which isnt like the ones that were provided, should be the same? (i use these taps on my car so i believe they are fine, just checking all corners.)
btw tyler thank you for your help.
Any chance you sell premade DDE harnesses w/ remote kit? finding time to build one, though cheap, requires about a day's worth of time for me which i often do not have.
Old 10-11-2006, 12:30 PM   #10
Tyler@UniqueDesign
Car Junky
Its the ECU tap because of number 2.
I was referring to the fuse on the harness.
The 18-22 gauge taps should be fine, I think the wire is a 16 gauge wire so they usually cut a few strands rather than not getting far enough through the insulation.
I can sell the harnesses, but they cost like $40.
Go to walmart or discount auto (or pepboys, but its more there). Look for an auxilary lights wiring harness, APC or pilot are the two brands I've seen. Has white sleeving on the wires comes witha ricey swithc and a 4 pin relay.
Won't use the remote kit but its $10.
Old 10-12-2006, 10:00 PM   #11
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
tdevil, listen to your retailer. Whomever that is.
Old 10-13-2006, 12:46 PM   #12
tdevil
My Ride: 03 325i
These DDEs are actually bought from you, umnitza. I've been asking these questions for my friend.
The wiring for DDEs are 95% the same(or maybe i am stupidly mistaken) so i didnt want to so i didnt feel the need to point out where i got it from.
Old 10-13-2006, 04:14 PM   #13
umnitza
8774866489
umnitza's Avatar
If that's the case, and they are purchased from us - then definitely listen to your retailer, contact us so we can resolve it.
Old 10-14-2006, 03:56 AM   #14
tdevil
My Ride: 03 325i
well could you start by confirming the correct color wire to tap in the ECU area?
Old 10-14-2006, 10:25 AM   #15
umnitza
8774866489
umnitza's Avatar
red wire/white stripe/spade connector - into red wire/yellow dots/white stripe.
Old 10-16-2006, 05:01 PM   #16
tdevil
My Ride: 03 325i
ok guess i will try again. i believe this is the wire i used originally.
Old 10-29-2006, 10:16 PM   #17
tdevil
My Ride: 03 325i
Yea still problematic.
so the pink wire was no good, scrap that idea.
we retried the red wire/yellow dots/white stripe which i had originally tapped. It worked for abit now the interior light switch doesnt even turn on the interior lights. So some kinda short is happening.... somewhere.
im going to try and remove the ecu tap and see what happens.
Old 10-29-2006, 10:32 PM   #18
djmatty
Banned
djmatty's Avatar
My Ride: Black '99 328i Sedan
Send a message via AIM to djmatty
From what it sounds like, the ECU tap was fine in the first place, it was the source wire that wasn't fine. When you started your car, the ECU wire would become hot, flipping the switch inside the relay to use the source wire instead of the footwell lighting tap. Since the source wire wasn't supplying the relay correctly (whether it's a blown fuse or bad connection, i'm not sure), and thus, the DDEs would be off.
djmatty is offline   Reply With Quote
Old 10-29-2006, 11:57 PM   #19
tdevil
My Ride: 03 325i
source wire? you mean the one that is directly connected to the + terminal?
once we took the ECU tap off, now everything is back to as it was. Cabin lights turn on/off the DDEs.
Old 10-30-2006, 06:16 PM   #20
tdevil
My Ride: 03 325i
i think im going to just wire the motherf*ing ECU wire to the pos terminal and put a switch and fuse in between because this sh1t is getting rediculous.
i forgot to check case 3 tyler, ill go do that soon.
