Sponsored by The Tire Rack
Old 10-02-2006, 10:37 AM   #1
Asterisk*
Banned User
My Ride: gives me blue balls
Send a message via MSN to Asterisk*
Question What tire brand is the best for stretch?
Tia.
Asterisk* is offline   Reply With Quote
Old 10-02-2006, 10:39 AM   #2
Jeuprx-8
My Ride: rolls only Michelins
Originally Posted by Asterisk* View Post
Tia.
The PS2 is a larger than average tire, if that is what you are asking.
2006 Corvette Z06 Red/black
2006 BMW M5 Sepang/Sepang SMG III
2006 BMW M6 White/Black 6-speed
Jeuprx-8 is offline   Reply With Quote
Old 10-02-2006, 11:10 AM   #3
Asterisk*
Banned User
No. I'm asking which tires can perform better then the others when stretched.
Here's an example:
Old 10-02-2006, 02:22 PM   #4
api
My Ride: 03 M3 6-spd
I was very happy with my Falkens. Both the FK-451 and AZENIS ST-115 have sidewall protections so if you run flat there is some support so you do not just run on the rim.
Hope that helps
api is offline   Reply With Quote
Old 10-02-2006, 02:48 PM   #5
Asterisk*
Banned User
Do you have pics? And can you tell me sizes you're running? Thx.
Old 10-02-2006, 03:24 PM   #6
m3on20z
Sh!t Happens.
My Ride: W203 dumped on 20's
Send a message via AIM to m3on20z
I had Yokohama AVS Sports on my old 3er. I liked them, but they wore quickly.
m3on20z is offline   Reply With Quote
Old 10-02-2006, 03:41 PM   #7
PYRITE
My Ride: 1965 Ford Mustang
http://forum.e46fanatics.com/showthr...49#post4950249
Falken FK-451s have a nice stretch, DO NOT get 452's if you want a stretch, they are now cut wide...
PYRITE IS SOLD!!
Welcome "KRYPTONITE"...
PYRITE is offline   Reply With Quote
Old 10-02-2006, 04:00 PM   #8
Asterisk*
Banned User
^ My front is gonna be 9 and I'd like a more aggressive stretch. Maybe like 45-50 degrees. Do you think I should go with 255s or 265s (FK-451)?
Old 10-02-2006, 04:40 PM   #9
Asterisk*
Banned User
Originally Posted by merong View Post
rear: 10x16 on 225/40/16
front: 9.5x16 on 215/40/16
I want something with this degree angle stretch. On 19x9 ans 19x11.
Old 10-02-2006, 05:11 PM   #10
PYRITE
Go 255FTEUROWIN
PYRITE IS SOLD!!
Old 10-02-2006, 06:54 PM   #11
hosagod
My Ride: Facelift Ci
Good God Asterisk lol. stretcccchhhhhhhhhhhh...
I agree, go 255.
hosagod is offline   Reply With Quote
Old 10-02-2006, 10:13 PM   #12
Asterisk*
Banned User
What about General Exclaim? Are they good for stretch?
Old 10-02-2006, 10:34 PM   #13
ryan325i
My Ride: is Gay
nope! the sidewall is too square type, you need falkens, just like pyrite showed, used falkens before on 9.5 rims w/ 235's.
MILANO MOTORING EURO-SPEC
ryan325i is offline   Reply With Quote
Old 10-03-2006, 08:58 AM   #14
Asterisk*
Banned User
Some info found on VWVortex forum. Credit goes to billcosbyluvsvr6s.
what is stretch?
- "stretch" refers to stretching a narrower tire over a wider wheel, the sidewalls stretch from the lip to the tread
why do stretched tires?
- well the whole thing started in germany/belgium, local laws required that the tire tread be within the fender line. well that doesnt allow one to run wider or lower offset wheels, so they put narrower tires on the wheel to maintain legality
- when you would like to run really wide or low offset wheels and keep the tire tread at the fender
- when you would like to go really low and not rub
isnt this unsafe?
- there hasnt been any soild evidence that running a stretched tire is any more dangerous than a regular tire.
where can i get tires stretched?
-any reputable wheel/tire shop should be able to do it. i know when i did a 215-45 kumho on a 8.5" wheel, it took one shop 90lbs to pop the bead. getting a 225-45 on a 9 and a 245-40 on a 10.5 took another shop 50 lbs
can't you afford the right tire size?
- the tire that stretch the most tend to be at the top of the price list, so it isnt an issue
what tires stretch best?
- from what i have seen, the best tires with regards to stretch are:
toyo t1-s
dunlop sp9000
dunlop sp8080e
falken fk451
im sure there are more, but look for a tire with a rounded shoulder and a lip protector, they tend to give the "desirable" look
but staggered wheels are stupid on fwd cars, arent you worried about handling?
- its all about looks, you wont see anyone with low offset deep dish wheels flopping around the autox course.
arent you worried about curbing a wheel?
- take a look in the classifieds and count the number of wheels on regular tires compared to those on stretched tires with damage.
what if you get a puncture in the tire from a nail and you're going 65mph and the tire loses air rapidly, will it stay beaded (proper term?) as long as a regular sized tire would? do stretched tires need to have above a certain tire pressure to stay beaded?
- one thing about running stretched tires, the driver tends to be a bit more careful because of the cost of the wheels, i definately drive more alert with the tramonts than i do my stock wheels.
and as far as loss of pressure is concerned, i tested my wheels the other day after putting them on, i drove around one day (~60 miles mixed highway/city) and one tire was at 10psi, no visual or performance cues.
the main reason for a tire popping a bead is sidewall flex, not internal pressure. like i said, it took ~90lbs to mount my one set, there is no way that driving forces would add to exceed that pressure, let alone the 40lbs it took to do this set
from my understanding, stretching tires is just putting smaller tires on a bigger rims, like 215 on a 19"x8.5 or something like that. But to get that tire outside the fender, dont we need spacers or something? or as long you have stretch tires, you will achieve "the look" on the rear wheels?
- you can do one of 2 things: 1 - use spacers, 2 - pick a wheel or have one made that provides an offset such that when mounted it will have the look you want
ok, it seems clear now. what et usually gives that kind of look? and with that kind of offset or by using spacers, wont the tire tread falls under or outside the fender just like that? If it is, then why we need to stretch the tires again??
- the thing is that in most cases people are running a wide, low offset wheel, which would allow them to run a large amount of dish...
the proper offset for a mark 4 front fender is about 30-32 with an 8.5" wheel, but with the strech idea, one could run a 20-25 (would poke outside the fender about 1/2") without rubbing and without being against the law.
Old 10-04-2006, 04:39 PM   #15
Asterisk*
Banned User
So I should order:
255/35/19 on 19x9
and
275/40/19 on 19x11 ???
Please confirm.
Old 10-04-2006, 06:06 PM   #16
Souljah
My Ride: 2008 AW/Coral 335i
I don't know why you guys want that stretched looks anyways...looks like ****...unsafe too...rims gonna get curbed easier etc...
Souljah is offline   Reply With Quote
Old 10-06-2006, 02:06 PM   #17
api
Here are pics of my Falken AZENIS ST-115 255/35/18 on mt 18"x10" Brocks
Old 10-06-2006, 02:18 PM   #18
api
Just because you don't like it does not mean that everyone thinks it looks bad. If everyone had cars that looked the same they would be boring. I never had any problems with my stretched tires but I also did not track that car either.
Old 10-06-2006, 02:23 PM   #19
russ330
Mod Squad
russ330's Avatar
My Ride: Motorsport III
Send a message via AIM to russ330
Great thread
I gotta keep this one in mind, "just in case."
russ330 is offline   Reply With Quote
Old 10-07-2006, 04:51 AM   #20
Z4EC
Banned
My Ride: Z4
Yeah I have to agree. The stretched look just seems too ghetto to me.
Z4EC is offline   Reply With Quote
