Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 10-02-2006, 08:04 PM   #1
5speedsteve
My Ride: gets rid of hickups
Exclamation DIY: Coilover Install!! StepbyStep BoltbyBolt
Hey, Ill get right to the point ...take a deep breath
Tools: 13mm, 16mm, 17mm, 18mm, 21mm, Hammer (tierods)egh Sockets and Wrenches are needed as well as Impact Gun...hmm what else...Ham sandwich mayb..
Coils: Bavarian Autosport $699.95 http://www.bavauto.com
- Drive car with lots of wheel gap on to lift ( I've done this install with out a lift before but that was on a Coraddo)
- Before you lift up the car take off the the rear shock tower bolts theres 2 on each shock 13mm
Now lift the car and take the wheels off. The rear shocks fall down
Now take out the bottom shock bolts, one on each shock. 18mm
Pull down on the rotor and pull out the spring
New Coils - We mesured an inch differance from the stock one
Put the Hat on the top of the shock and put it all in place.
Then take the new rear shocks and cut the old bump stops.
Place the new mount on top and screw it down
Ready!
Now Put the new shocks In
Screw in Buttom Bolt
Put new Gasket on top of the new mount
Now a lil tricky and theres probably a safer way ..but hey! lol. Put the Rear Wheels on and lower the car with jack stands under the wheels.
Guide the Shock bolts into the wholes
mmmm now tighten those bolts
Bammmm the rear is done....here comes the front!
330xi VF Charged Widebody
5speedsteve is offline   Reply With Quote
Old 10-02-2006, 08:27 PM   #2
ironicdesigns
Account Under Review
My Ride: 335i
Send a message via ICQ to ironicdesigns Send a message via AIM to ironicdesigns Send a message via MSN to ironicdesigns Send a message via Yahoo to ironicdesigns
hella pimp! do you think this could be done w/ only jackstands?
ironicdesigns is offline   Reply With Quote
Old 10-02-2006, 08:31 PM   #3
5speedsteve
The Front!!
Okay Take the Mount Bolts off 13mm Theres 3 for each strut
Unscrew the 18mm Bolt on the bottom now Theres 1 on each
Carefull with your lines
Unless your real clever take the tierod bolts out 18mm. If they dont budge hit the rod with a hammer.
Take out the Sway Bar links - You need a 16mm or 17mm I forget - but you need to hold the inner part with an open end wrench while you loosein the bolt with a socket. 2 bolts on each strut
Now Lift and turn the strut untill you can yank it out of the car
wheww
Okay now check it out this is the old strut mount - notice the angles of the bolts.
This is how they should be like the new ones
So you have to hit the top of the strut case with a hammer and piece of wood to even out where the bolts go.
Or don't its up to you....the guys that are helpin me are pros and all they do is brakes, suspension, and tires for sport cars...so I trust them.
Now take the Front Coils and put the New strut Mounts on top of them.
You need to put this washer inbetween the strut mount and coilover before you tighten them. You can use a new washer or get it off your old struts.
Now you can put it back in the arm.
Tighen the bolt and hook your lines back up 18mm
Do the Sway Bar Links - The new ones are smaller - they were included in the kit- Again 16mm or 17mm
Put your tierod back in 18mm
Put a jack underneath the control arm and jack it up lineing up your bolts
Tighten the bolts up Top 13mm
Old 10-02-2006, 08:41 PM   #4
5speedsteve
BAMM ur golden
Now we measured the front an inch from coilover screw to base of threads and we lowered the rear like 1/2 inch more.
Put your wheels on!
Some wood in the front will help you get the lift out from underneath
This is how it sits.
Old 10-02-2006, 08:46 PM   #5
ironicdesigns
My Ride: 335i
they ahve a 335 on the lift int he final picture, know wht they're up to?
Old 10-02-2006, 09:00 PM   #6
5speedsteve
funny u mentioned it lol i was about to start raving about it
http://forum.e46fanatics.com/showthr...31#post4951931
Old 10-02-2006, 09:01 PM   #7
5speedsteve
if i only had jackstand id attempt the install as long as i had the impact gun
Old 10-03-2006, 12:21 AM   #8
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
how is the feel of em? can u go any lower?
BreakMyWallet is offline   Reply With Quote
Old 10-03-2006, 01:55 AM   #9
DarXide
DarXide's Avatar
My Ride: Slammed on F2's
Send a message via AIM to DarXide Send a message via MSN to DarXide
Can you go any lower? if so how much?
Cool DIY..
FS 20'' Avus 3 piece wheels with tires 80% thread $2,000 + shipping
FS Brembo BBK 4 Piston 380mm front 345mm rear (silver) $3,800 + shipping
DarXide is offline   Reply With Quote
Old 10-03-2006, 10:04 AM   #10
5speedsteve
yea i could deffintly go lower--but first i wanna fill the car with ppl and see if i rub - the car feels solid everywhere
Old 10-03-2006, 11:02 AM   #11
DarXide
DarXide's Avatar
Niceee... I terms of thread left on the coils..how much more do you have to go?
Old 10-03-2006, 12:49 PM   #12
Alex
Mom says I'm a catch
Alex's Avatar
My Ride: E46
Send a message via MSN to Alex
Thanks for the write-up!
A lap dance is so much better if the stripper is crying.
Alex is offline   Reply With Quote
Old 10-03-2006, 11:03 PM   #13
5speedsteve
theres a lil more then an inch on the front and rear coils
Old 10-04-2006, 12:54 AM   #14
rkhettry23
My Ride: Has2Turbos & X-Drive
I could have used this a month ago....damnit but o well...I don't reccomend the install unless you have an impact gun...otherwise the nut on top of the hat on the front strut is a BITTTTTTTTTCH to get off....but sick write up anyway
-Raj
2009 535i w/X-Drive
2002 325xi--Parted Out
rkhettry23 is offline   Reply With Quote
Old 10-05-2006, 09:50 PM   #15
jefsbmw
My Ride: 328i
hows the ride quaility?cause i have a baby and i dont want nothing to stiff.lmk thanks
jefsbmw is offline   Reply With Quote
Old 10-06-2006, 07:50 AM   #16
5speedsteve
well its deffintitly stiffer in some degree however my old setup had 125,000 miles on them so anything new would be stiffer....i really dont think theyre harsh the ride seems very nice...i try to go over bumps and railroad tracks real slow but when I dont see one coming its not a hard thump or anything its a soft stiff sturdy feel.
Old 10-06-2006, 08:16 AM   #17
clinique
clinique's Avatar
My Ride: 06 M3 Vert
nice DIY
drop looks great
clinique is offline   Reply With Quote
Old 10-07-2006, 09:12 AM   #18
blksedan
My Ride: HATES thieves
nice write up
blksedan is offline   Reply With Quote
Old 10-08-2006, 08:45 PM   #19
deraufschneider
Landon Donovan Sucks
deraufschneider's Avatar
My Ride: '00 323i
I thank you for taking the time to do this write-up.
Props.
deraufschneider is offline   Reply With Quote
Old 10-08-2006, 10:39 PM   #20
3301SEDAN
My Ride: 2005 330i Sedan
nice write-up...I am thinking about installing my tein ss pretty soon as well.
3301SEDAN is offline   Reply With Quote
