Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 10-03-2006, 09:37 PM   #21
Christapher05
My Ride: .
Send a message via AIM to Christapher05
thats pretty sick!
Christapher05 is offline   Reply With Quote
Old 10-03-2006, 10:26 PM   #22
crovax
My Ride: 04 CB/Cinnamon M3
Send a message via AIM to crovax
where is bella motorsports in west palm?
Tom
04 M3
crovax is offline   Reply With Quote
Old 10-03-2006, 10:49 PM   #23
5speedsteve
My Ride: gets rid of hickups
Ernie Bello....hes in west palm yeah
330xi VF Charged Widebody
5speedsteve is offline   Reply With Quote
Old 10-03-2006, 10:50 PM   #24
5speedsteve
Old Oakachobee and Austrailian Ave.
Old 10-03-2006, 10:52 PM   #25
5speedsteve
i think the rims where 17's
Old 10-03-2006, 10:54 PM   #26
5speedsteve
hmmm mayb they were 18's i forget
Old 10-03-2006, 11:02 PM   #27
bimless
Banned
My Ride: a car
The 335's are really nice. It's one of the cars I'm considering for my daily driver.
bimless is offline   Reply With Quote
Old 10-04-2006, 06:46 AM   #28
RichP
Big in Japan
My Ride: Mid-engined Madness
That thing needs a more aggressive diff like a hole in the head. It just needs an LSD!
RichP is offline   Reply With Quote
Old 10-04-2006, 09:28 AM   #29
Alan L.
TWC Alumni
Alan L.'s Avatar
My Ride: AW M-Sport
The stock rims flowed better. The BBS looks too small and narrow. E92 needs a fat 5spoke wheel.
2015 F15 M Sport |||More Photos of my X5 here||| -F85 X5M Incoming....
Alan L. is offline   Reply With Quote
Old 10-04-2006, 09:51 AM   #30
crovax
sweet, ill have to stop by...maybe they'd be good with installing headers and cams... btw 335i is sooo damn hot.
Tom
04 M3
Old 10-04-2006, 10:54 AM   #31
downtoearth
My Ride: 2003 330i
Those are 19!!! and they still look small. a 3.46 woo guess it must be new parts too $$$$ as it'll be too early to find used parts on e92.
downtoearth is offline   Reply With Quote
Old 10-08-2006, 10:38 PM   #32
3301SEDAN
My Ride: 2005 330i Sedan
sweet
3301SEDAN is offline   Reply With Quote
Old 10-09-2006, 03:20 PM   #33
bmwnetgui
My Ride: 01 330 & 03 996c4s
Send a message via AIM to bmwnetgui Send a message via Yahoo to bmwnetgui
Very impressive.
Sig by Hi it's me alec
moore technology consulting
www.moore-tech.com
347 682-5711
bmwnetgui is offline   Reply With Quote
Old 10-09-2006, 03:35 PM   #34
GBX330ci
My Ride: 2011 Cayenne 6sp
Send a message via AIM to GBX330ci
exactly. Turbo'd cars benefit from higher ratio diff, right? No reason to switch to a lower gearing, except if you want to lose boost pressure
GBX330ci is offline   Reply With Quote
Old 10-09-2006, 08:29 PM   #35
rsalicrup
rsalicrup's Avatar
My Ride: 330i & Titan
Send a message via AIM to rsalicrup
Boost pressure is built in exhaust gases and engine load. Has NOTHING to do with final drive. If anything would be from lower final drive to get more load.
But Boosted car can benefit from a longer first gear to take advantage of the turbo quick spool up and not waste it on tire spin and rev limiter coming so fast.
Rick
rsalicrup is offline   Reply With Quote
Old 01-03-2007, 06:25 AM   #36
bimmerZ5
My Ride: Z3 3.0i, E39 3.0i
however, you have to take into consideration this is not a traditional turbo setup. there's a small turbo that spools up boost quickly while another larger turbo kicks in at the higher end. a lot of the know-how with traditional turbo setups don't apply in a straight forward way here...
bimmerZ5 is offline   Reply With Quote
Old 01-03-2007, 08:46 AM   #37
tpzblu330ci
TheOnlyConstantIsChange
My Ride: '11 Golf TDI
Send a message via AIM to tpzblu330ci
Thats not how this turbo system works. Its not a sequential set up. Equal sized turbos are attached to 3 cylinders each and provide their own boost to each side. BMW preferred to use smaller turbos with quicker spool on each "bank" to ensure low end torque. Regardless of how the turbos are set up final drive still means nothing in the power category.
"Every man gotta right to decide his own destiny." - Bob Marley
'93 Toyota LandCruiser
tpzblu330ci is offline   Reply With Quote
Old 01-03-2007, 09:07 AM   #38
bimmerZ5
You're right about the twin turbo setup. I was thinking of BMW's twin turbo diesel engine that has a sequencial turbo setup.
However, gearing does influence the drivability of a turbo engine car. Just as an example, off line in 1st gear, the car with the higher multiplying gear ratio is going to reach a lower RPM than the same car with a lower multiplying gear ratio at the same speed. Hence, as an example, at say 40mph, one car will be at 3000 RPM vs the other car will be at 4500 RPM. If your boost doesn't kick in until 4000RPM, then having the gear ratio that gets you in that RPM range quicker will make getting into the "boosted zone" easier. Typically, the car that gets into the boost zone quicker will be faster. At higher speeds, this becomes less significant as you can choose to use a lower gear to keep your revs up, and hence in boost. At lower speeds, you only have a few choices in gears and you can't go lower than 1st.
In any case, if this engine uses smaller turbos that kick in at lower RPM ranges, then a lot of this matter less.
Old 01-03-2007, 10:50 AM   #39
lennon31987
lennon31987's Avatar
My Ride: imolarot II M
Send a message via AIM to lennon31987
Originally Posted by BMWPower06 View Post
better low end power+more torque and around the same weight its a close race with top end going to the 335i
top end goes to the m3, idont know what your talking about
Last of the best-
ILLm3 hates me cause im GGGOOODLOOKIIINN
seeking detailing perfection?
lennon31987 is offline   Reply With Quote
Old 01-03-2007, 07:27 PM   #40
tpzblu330ci
Oh indeed gearing changes drive ability but not actual power output of the engine. We reach agreement on that. As you said at the end BMW has elimated both of the cons of FI engines by going with this setup. Gearing can be kept the same as their NA engines because torque is available throughout the range and boost lag is non existant as well.
