Old 10-02-2006, 09:03 PM   #1
bimmerboy36
My Ride: 02 Sk+ 330ci
oil seeping into combustion chamber
So I had some problems wiht my car this past weekend.
THere was tons of white smoke coming out of exhaust. The RPMs would fluctuate while driving. After having a compression test done today, thank god the engine is fine.
However, they did determine that the supercharger is leaking oil somewhere into the motor. I'm having it towed to Technik tomorrow morning for Zolti to have a look.
I need new spark plugs and an Air Flow Sensor to go with it.
Any ideas of where the leak might be? Also anybody know how much the spark plugs and sensor will be?
Any help is appreciated.
Thanks,
Henry
02 ASA sk+ blown 330ci
C.S.U.N. Fanatics Sign Up!!!
http://forum.e46fanatics.com/showthr...51#post4894951
bimmerboy36 is offline   Reply With Quote
Old 10-03-2006, 02:26 PM   #2
MarvelPhx
www.my330i.com
My Ride: E92335i,04ZHP,99M3
Send a message via AIM to MarvelPhx
The first thing I would look at is the PCV connection. Especially if you drive around at high RPM alot.
MarvelPhx is offline   Reply With Quote
Old 10-03-2006, 02:51 PM   #3
steelgrey330ci
My Ride: 2002 330ci
well I noticed, that when i changed my Tm12 out to the TM15. They was alot of oil by the intake side.
19 x 8.5, 19 x 10 Hm2's/ASA CHARGER TM15 10.5 psi
Hamann Full Add-on kit/kw Varriant 2's coilovers
UUC Sway Bars/UUC M5 presure plate & 8.5lb flywheel
Sach II clutch/AA front and rear strut bars
Angle eyes/Technik Oil Cooler/Technik Headers
Technik FI cams 248/256/ 38lbs injecters
Supersprint Cat back/EVO 3 Short Shifter
Port & polish head, Ferra valves
Dyno 388RWHP & 325TQ To the wheels
CAR IS SOLD
steelgrey330ci is offline   Reply With Quote
Old 10-03-2006, 05:48 PM   #4
bimmerboy36
My car is with Zolti @ Technik right now. I'm sure he'll figure it out. He says that if it's the compressor, they should be able to replace it for me under warranty. Glad I chose to have it installed by them originally. I'll fill you guys in when i find out more myself.
