final checklist - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-04-2006, 04:02 AM   #1
redronin
My Ride: 330ci
final checklist
to make it short, i just needed a couple reminders of what i should change out when i install boost
0. kit (check)
car (check)
1. gaskets (check)
2. samco upgrade hoses (check)
3. 8psi pulley (i just need pulley and belt for this correct?, will still work with ASAtronic?
4. SPARK PLUGS iridium IK22s are the ones to get after a quick search
5. injectors? what size injector should i use, who sells them and how much?
anything else i should grab before install? how about anything i need to install the ASAtronic with? have the small metal box thing that gets spliced into the ecu. not really sure how FPRs work
TIA sorry if this info is readily available, very tired and thinking about cars > thining about schoolwork
redronin is offline   Reply With Quote
Old 10-04-2006, 05:54 AM   #2
BayerischeMW
Man with No Name
BayerischeMW's Avatar
My Ride: '07 E92 335i
are you buying a kit or going custom? if it's a kit, then injectors will be included.
BBS | ACS
"if you wanna be king of the ring, this is the kind of car you should get" -M3 CSL
"there's no replacement for displacement" - only BMW ///M
BayerischeMW is offline   Reply With Quote
Old 10-05-2006, 12:39 AM   #3
redronin
My Ride: 330ci
kit is made for use with stock injectors, wondering if better ones would be beneficial
