Clear tail light carrier won't snap into place - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-07-2006, 12:12 AM   #1
wannbracer
My Ride: 2001 325CI
Started doing my clear tonight and after finally finding the third nut got the OEM's out and clears in. No problem. Well, just one. The damn light carrier won't snap into place. Who else has had this problem and how'd ya fix it?
wannbracer is offline   Reply With Quote
Old 10-07-2006, 12:48 AM   #2
325ci GreekMan
My Ride: 325ci steel gray
dont force nothing. i had trouble with mine but i just stood back took a look at everything then with a calm and rational manner I snapped that puppy in place.
325ci GreekMan is offline   Reply With Quote
Old 10-07-2006, 01:22 AM   #3
Hobbes330i
Addicted!
Hobbes330i's Avatar
My Ride: Jet Black 330i
Are you using the light carrier that came with the clears? I remember the light carriers are keyed so you cannot put amber carriers with clear lens and vice versa.
If you are having a hard time turning the screw, try turning the screw counter-clockwise all the way first.
Jet black 2005 330i Xenon - Step - Homelink - Sirius - DDE Enhanced v2 - ECIS Intake - OEM Clears - ACS replica Roof Spoiler - UUC Stage 4 - UUC SS Brake Lines - ///M3 Steering wheel - 35% Tint
Hobbes330i is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-07-2006, 09:03 AM   #4
wannbracer
My Ride: 2001 325CI
No that's not the problem.
The OEM carrier that houses the three bulbs that has the wiring harness attached to it that snaps back into the center of the new clear lens housing that is attached to the rear quarter panel. It is bumping into something that is preventing the housing from snapping securely into place. I can't see what it's hitting.
I have tried fitting the carrier from the drivers side into the housing in the clear lens before mounting the lens and everything seems to fit as far as OEM and the aftermarket lens.
What am I missing? This should only have taken 20-30 mins to done both sides.
Old 10-07-2006, 09:49 AM   #5
2005_330xi_BMW
My Ride: 330xi
I have this problem sometimes, what you need to do, if you have the same problem as I do, it look at the male connector on the carrier, and the female connection on the tail light. Understand the mechanics of how the pieces connect. The snap piece on the carrier needs to be pushed out (towards the fender) sometimes in order to get it to stay. ALSO, make sure nothing is blocking the carrier from seating correctly on the tail light. Try to work the carrier on from side to side, not just directly snapped on front to back, but be careful of the bulbs.
Take your time, you should be able to figure it out, if not, you might have bad parts.
2005_330xi_BMW is offline   Reply With Quote
Old 10-07-2006, 12:27 PM   #6
wannbracer
My Ride: 2001 325CI
Problem found
I'm not an idiot! Not a fabricator either but at long last. There was a tab on the inside that should have been removed or not there to begin with after the lens was molded that was preventing the bulb carrier from seating completely. 2 secs with a dremel tool and presto, it's done.
I'm pissed it took that long for me to find it. Thanks for the help gang.
Mod #1 in the bag!
Name:	Bav lens 1.jpg
ID:	199032   Click image for larger version
ID:	199033   Click image for larger version
Name:	OEM Amber front.JPG
ID:	199035   Click image for larger version
Name:	Clears front.JPG
Name:	OEM Lens 2.jpg
ID:	199037   Click image for larger version
Name:	Clear tails.JPG
Old 10-07-2006, 03:02 PM   #7
ikeupinya
Stay modded my friends!!!
ikeupinya's Avatar
My Ride: 05 ZHP
Same thing happened to me Bro!!! Now continue on your quest of moddin'!!!
Da Lil' Paratrooper!
ikeupinya is offline   Reply With Quote
Old 10-07-2006, 03:17 PM   #8
Alex323Ci
My Ride: M3 & 323Ci (sold)
Sorry I didn't see your thread yesterday. I knew exactly your problem the moment I read it. My guess is that the Euro lens have the extra tab for the euro lamp carrier. So you have to cut the tab off so it sits down. The red mark with arrow is the one I had to do when I had clear tails on a US model.
*LEDs tails do not have this issue if anyone notices I have LEDs now.
Old 10-07-2006, 05:33 PM   #9
2005_330xi_BMW
My Ride: 330xi
You took the time to understand how it all worked, then fixed it... good man!!
Old 10-07-2006, 10:29 PM   #10
325 & 55
My Ride: 2001 325Ci Step
Clears...
look great and nice job at correcting the fit.
IMO, your "clears" would look even better with some SilverVision bulbs and toss the amber
325 & 55 is offline   Reply With Quote
Old 10-20-2006, 03:05 PM   #11
JL
My Ride: 2002 325i
Thanks for the tip. I had some electrical problems where my left bulb carrier was busted and unusable. I thought that I had to buy a whole new bulb carrier, but because of your post, I was able to just snip off that plastic piece and use the bulb carrier that came with my ambers.
Put in some Silvervisions and I'm ready to go.
JL is offline   Reply With Quote
